Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Hello! What is the advantage of at function in SMath ? Appreciate if any useful example is provided. Cheers ! Edited by user 07 June 2023 17:43:21(UTC)
Hi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the ' eval' in maple, although it also has a 'subs' function, and even another one like ' algsubs', or Mathematica's f /. x -> a notation, and perhaps there you can see how those programs use it and get a better idea of what it might be useful for. I also remember that den derive, which did not have a function like at, could be used instead ... take the limit: lim f for x -> a Best regards. Alvaro.
Originally Posted by: Razonar Hi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the ' eval' in maple, although it also has a 'subs' function, and even another one like ' algsubs', or Mathematica's [b]f /. x - Hi Alvaro, thank you very much for your kind sentiments and valuable clarifications. |
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1126 time(s) in 723 post(s)
Electron function added Φ(x,y) This function has no symbolic solution. It plots X_Y but for QuickPlot, you need solving. Cheers ... Jean. Solve at(2), at(3).sm (48kb) downloaded 5 time(s).
Hi, Thank you all for the clarifications and examples |
