Offline OchkovVF
#1 Posted : 15 May 2023 19:56:26(UTC)
OchkovVF
Was thanked: 28 time(s) in 27 post(s)
See please the attach Raschjot STU.sm (293kb) downloaded 34 time(s).
Offline Razonar
#2 Posted : 01 June 2023 00:00:52(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Hi. I don't understand how you get Q5 = 77.8518 % given that at T5 = 32.88°C and P5 = 5 kPa it must tu be Q5 = 50 %.
This is a more direct way of solving the problem, in the sense that the same results are obtained. A great advantage of using functions of two variables for thermodynamic variables is that now you don't have to look them up in tables, and therefore you no longer need to separate the vapor and liquid parts to find them in tables.
Raschjot STU.sm (575kb) downloaded 16 time(s).
Edited by user 01 June 2023 02:09:13(UTC)  | Reason: Alternate solution added.
Offline OchkovVF
#3 Posted : 01 June 2023 09:03:16(UTC)
OchkovVF
Originally Posted by: Razonar Go to Quoted Post
Hi. I don't understand how you get Q5 = 77.8518 % given that at T5 = 32.88°C and P5 = 5 kPa it must be Q5 = 50 %.
At T5 = 32.88°C and P5 = 5 kPa it Q5 must be from 0 % to 100%.
If Q5=50% - it is not a steam turbine - it is a 50% steam turbine and a 50% water turbine ;-)
Calculation with WaterSteamPro
Edited by user 01 June 2023 09:34:10(UTC)  | Reason: Not specified
Offline Razonar
#4 Posted : 01 June 2023 13:24:44(UTC)
Razonar
Uruguay
If Q5=50% - it is not a steam turbine - it is a 50% steam turbine and a 50% water turbine ;-) ...
You're right. I put the numbers backwards. The correct question is why do you use Q5 = 50% since the correct value is Q5 = 77.85%?
In the attached file, in addition to showing the most direct way to calculate all the states, the T-s and T-h diagrams are added.
Raschjot STU Ideal.pdf (399kb) downloaded 19 time(s).
Raschjot STU Ideal.sm (309kb) downloaded 26 time(s).
Offline OchkovVF
#5 Posted : 01 June 2023 22:22:49(UTC)
OchkovVF
We can use Q=1, 0, 77.85% etc
Similar Topics
Thermal efficiency of an ideal Rankine cycle on superheated steam (Samples)
by OchkovVF 16/04/2024 04:23:59(UTC)
