Offline Chinmoy Kolay
#1 Posted : 27 May 2023 04:30:49(UTC)
Chinmoy Kolay
India
MathWithinTextProblem.sm (5kb) downloaded 10 time(s).
I am trying to use embedded formulas within the text region. When I define some variables within a text region and use them to perform some calculations within the same region, it works. But when I try to do the same calculation in a new text region, where the variables are defined earlier in a different text region, the formula does not work. Please find attached a minimum working example. This behavior is not expected. Is it a bug? Please help.
Offline overlord
#2 Posted : 27 May 2023 13:24:01(UTC)
Turkey
Confirmed, probably this is a bug.
When math region a=15 is disabled, text region calculations are not performed.
When any variable of text region is calculated at math region, all calculations are done.
Offline Kenny Lemens
#3 Posted : 30 May 2023 15:52:19(UTC)
Kenny Lemens
Was thanked: 61 time(s) in 38 post(s)
Greetings,
Curious enough, it appears that if there is any mathematical evaluation in a math region above the afflicted Math-in-Text Region; it behaves as expected and produces a result.
Also, I am running appVersion(4) = "0.99.7822.147"; I don't think this is caused just by the latest release.
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
