Offline Orlando
#1 Posted : 17 May 2023 17:23:59(UTC)
Orlando
Peru
I am learning how to use Smath Studio, I want to write an iteration where an increment of 0.5 is added to two declared variables "a" and "b" which are replaced in a formula and it gives me a final value "X" and the condition is that the iteration stops when the final value is equal to or less than a declared value "Y" to finally extract from the iteration array the row with the three values that meet this condition: [a b X]
I appreciate your help in advance, I am willing to donate
#2 Posted : 17 May 2023 19:25:27(UTC)
Show your departure work, to be more helpful.
Iterate Demo.sm (48kb) downloaded 5 time(s).
Offline Orlando
#3 Posted : 18 May 2023 01:09:05(UTC)
Orlando
Peru
This is the structure that I have been writing to iterate but I need to extract the row of interest, which in this example has to be less than or equal to sigma_adm_suelo, this row is the last
matrix_programming.sm (14kb) downloaded 7 time(s).
Offline Orlando
#4 Posted : 18 May 2023 01:46:44(UTC)
Orlando
Peru
I already resolved it
matrix_programming.sm (14kb) downloaded 10 time(s).
Offline Kenny Lemens
#5 Posted : 18 May 2023 15:27:13(UTC)
Kenny Lemens
Was thanked: 62 time(s) in 39 post(s)
Greetings,
You may want to consider the use of a for loop instead of a while statement:
Copy and Paste the following into your worksheet:
Code:
line(#,for(i:1,i<10,i:i+1,line(#,#,#,#,4,1)),#,3,1)
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
Offline Orlando
#6 Posted : 18 May 2023 16:20:07(UTC)
Orlando
Peru
Originally Posted by: Kenny Lemens Go to Quoted Post
Greetings,
Code:
The result I am looking for is that it meets the initial condition, how would I stop at the iteration that meets this condition, to be able to do it using the "for" command that you suggested and not the 10 iterations that I declare for "i"
matrix_programming_for.sm (17kb) downloaded 4 time(s).
Offline Razonar
#7 Posted : 18 May 2023 18:01:52(UTC)
Razonar
Uruguay
Was thanked: 819 time(s) in 518 post(s)
Hola Orlando. You can use break inside the for loop.
matrix_programming_for.sm (18kb) downloaded 6 time(s).
#8 Posted : 18 May 2023 18:05:01(UTC)
Kenny Lemens
Greetings,
The 'i < 10' statement would be replaced with your criteria (ie., ≤ σ.adm_suelo). Regardless, the largest issue you have is with regards to how SMath programs; you need to follow the 'rules' of setting up programming functions within a line() group, where the last item is the value returned as a result.
Copy and paste the following into your worksheet:
Code:
C.summary:+line(C:matrix(max_rows:1,3),for(i:1,({1.075*(P.CM+P.CV)}/{B.zap_0*L.zap_0}-{6*(M.CMx+M.CVx)}/{B.zap_0*L.zap_0^2}+{6*(M.CMy+M.CVy)}/{L.zap_0*B.zap_0^2}≤σ.adm_suelo),i:i+1,line(el(C,i,1):B.zap_0,el(C,i,2):L.zap_0,el(C,i,3):{1.075*(P.CM+P.CV)}/{B.zap_0*L.zap_0}-{6*(M.CMx+M.CVx)}/{B.zap_0*L.zap_0^2}+{6*(M.CMy+M.CVy)}/{L.zap_0*B.zap_0^2},B.zap_0:B.zap_0-Δ,L.zap_0:L.zap_0-Δ,5,1)),C,3,1)
The matrix produced by C.Summary should be what you are after (I simplified the equ by removing Maxima() function calls)
#9 Posted : 18 May 2023 18:05:09(UTC)
Maxima is not popular in the Smath Community users.
Don't even recall a single of those decoration gyzmas.
matrix_programming (1) Ignore Maxima.sm (15kb) downloaded 5 time(s).
Offline Orlando
#10 Posted : 18 May 2023 18:57:44(UTC)
Orlando
Peru
I have a problem, the power went out and now my file does not open. What can I do, does anyone know how to restore it?
ZAPATA_AISLADA.sm (155kb) downloaded 8 time(s).
#11 Posted : 18 May 2023 19:08:04(UTC)
Was thanked: 1339 time(s) in 878 post(s)
Hello Orlando,
I'm sorry but the file is not recoverable (is filled with null characters).
#12 Posted : 19 May 2023 13:53:04(UTC)
Code the while loop from reconstruction.
Offline Orlando
#13 Posted : 19 May 2023 18:47:36(UTC)
Orlando
Peru
ZAPATA_AISLADA - AVANCE.sm (144kb) downloaded 6 time(s).
Hello, I have already made progress with a new file, I used the "for" command and after extracting the first matrix with the values that meet the condition, I made the next iteration with another formula compare the first two columns and extract the matches next to the third column that has a different result, thanks for the help to all of you, I will continue posting new concerns and I will make my donation to smath studio
