9 Pages«<789
Offline Razonar
#161 Posted : 18 April 2023 08:22:20(UTC)
Razonar
Uruguay
Draghilev's method for the Solve Block.
DraghilevSolveBlock.sm (550kb) downloaded 34 time(s).
DraghilevSolveBlock.pdf (1,462kb) downloaded 30 time(s).
on 18/04/2023(UTC)
Offline uni
#162 Posted : 18 April 2023 09:26:27(UTC)
uni
BTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension?
I haven't done this yet because I want the user to be able to choose the type of lines. For all sides.
Edited by user 18 April 2023 16:13:20(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline uni
#163 Posted : 18 April 2023 11:07:40(UTC)
uni
Unfortunately, I can't reproduce your parametric plot example.
It seems that the parameter range is taken from the x axis limits. Assigning a range to the parameter makes the plot fail.
How to fix this?
Links:
1. Added support for parametric plot type
Russia ☭ forever
on 18/04/2023(UTC)
Offline uni
#164 Posted : 29 April 2023 10:39:57(UTC)
uni
Theoretically, I can get data from any component. I can try to get the text from the text region.
Russia ☭ forever
on 29/04/2023(UTC)
Offline Razonar
#165 Posted : 29 April 2023 14:31:27(UTC)
Razonar
Uruguay
Originally Posted by: uni Go to Quoted Post
Theoretically, I can get data from any component. I can try to get the text from the text region....
Amazing: That's true for a lot of components! What about to catch the text in your memo editor instead SMath's text regions? Or both, I don't know.
Offline uni
#166 Posted : 29 April 2023 14:52:55(UTC)
uni
It's funny, I haven't tried it. I want to simplify the input of text programs. This is another way to extend the functionality of the program through third-party libraries.
A lot of useful libraries have been developed now. There is no point in repeating all this. It is necessary to create flexible interfaces for their integration and interaction with each other.
Russia ☭ forever
on 29/04/2023(UTC)
Offline Razonar
#167 Posted : 29 April 2023 15:39:33(UTC)
Razonar
Uruguay
... I want to simplify the input of text programs. ...
Yep. It would be very practical to have a tool to capture text to process it. I try to use description() function, but it has the drawback that it must be called at the worksheet level and it doesn't work well within the body of a function. Like in chess, RPN, Code or XYOptions.
Offline uni
#168 Posted : 29 April 2023 19:00:47(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- MathcadBlock: added support for TextRegion.
Click to enlarge
maple-system-python-TextRegion.sm (6kb) downloaded 18 time(s).
Russia ☭ forever
on 30/04/2023(UTC),  on 30/04/2023(UTC)
Offline uni
#169 Posted : 30 April 2023 19:14:56(UTC)
uni
Plugin updated.
Changes:
- MathcadBlock: added support for function definition.
Now the function definition can be written directly in the block.
Click to enlarge
maple-system-execute.sm (9kb) downloaded 24 time(s).
Memo Region also supported but it has not been updated for a long time, so some of its text functions do not work.
Edited by user 30 April 2023 19:43:28(UTC)  | Reason: Not specified
Russia ☭ forever
Offline mkraska
#170 Posted : 25 November 2023 14:25:40(UTC)
mkraska
Is there a chance to at least partially use units here? The values with units are disabled in the sheet, this is not visible in the png-file.
7-1.sm (30kb) downloaded 8 time(s).
on 26/11/2023(UTC)
Offline Razonar
#171 Posted : 25 November 2023 19:26:55(UTC)
Razonar
Uruguay
This is an option for having partial and full units support.
7-1-units.sm (36kb) downloaded 7 time(s).
Edited by user 25 November 2023 19:28:32(UTC)  | Reason: Not specified
on 26/11/2023(UTC),  on 26/11/2023(UTC)
Offline mkraska
#172 Posted : 26 November 2023 01:44:24(UTC)
mkraska
Alvaro, thanks for the hints.
By whatever reason, the unit of the independent variable is respected in rkfixed()=even though it is set to 1 locally. Whatever locally means if that happens in the last input parameter value.
7-1_units.sm (40kb) downloaded 4 time(s).
9 Pages«<789
