Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1125 time(s) in 722 post(s)
Originally Posted by: uni Thank you for the link, the book is really interesting and perhaps worth translating to German. At least I will use it for teaching. |
Quote:Thank you for the link, the book is really interesting and perhaps worth translating to German. At least I will use it for teaching. This is not the book itself, but the calculations that are used there. Unfortunately, the level of knowledge of the program leaves much to be desired. I made comments to the authors. |
Originally Posted by: uni Hi. Very interesting. It could be animated and add z axis. Maybe speed vectors too and the "ecliptic" plane. 3body.sm (38kb) downloaded 5 time(s).Best regards. Alvaro.
Originally Posted by: Razonar Hi. Very interesting. It could be animated and add z axis. Maybe speed vectors too and the "ecliptic" plane.
It is necessary to choose the conditions of the problem in such a way that the massive body intercepts the satellite. |
Originally Posted by: uni Quote:Thank you for the link, the book is really interesting and perhaps worth translating to German. At least I will use it for teaching. This is not the book itself, but the calculations that are used there. Unfortunately, the level of knowledge of the program leaves much to be desired. I made comments to the authors. So we can look forward for an inproved version. Could you please share your comments, eventually in PM... The pdf can be found here. I downloaded all the stuff from the companion site, who knows how long we can access this. Unfortunately, copying from the pdf to chatgpt for translation doesn't work |
Originally Posted by: mkraska Unfortunately, copying from the pdf to chatgpt for translation doesn't work You can find one of the authors here. He is open to suggestions and comments. Links: 1. Mathcad vs SMathEdited by user 02 April 2023 15:41:07(UTC)
Originally Posted by: uni Originally Posted by: Razonar Hi. Very interesting. It could be animated and add z axis. Maybe speed vectors too and the "ecliptic" plane.
It is necessary to choose the conditions of the problem in such a way that the massive body intercepts the satellite. Hi. Ok. 3body.sm (38kb) downloaded 14 time(s).Best regards. Alvaro.
on 02/04/2023(UTC), on 03/04/2023(UTC)
on 03/04/2023(UTC), on 04/04/2023(UTC)
Utility for call dsolvers for initial and boundary values problems from a solver block. RKA.pdf (932kb) downloaded 30 time(s). RKA.sm (309kb) downloaded 23 time(s).Best regards. Alvaro.
Hello I Can't Install the Mathcad Toolbox Plugin Best Regards Carlos Edited by moderator 05 April 2023 07:45:37(UTC)
Originally Posted by: CBG I Can't Install the Mathcad Toolbox Plugin
Does it happen only with this plugin or with others the same? Try deleting the plugins folder completely and try installing again. |
Originally Posted by: Razonar Utility for call dsolvers for initial and boundary values problems from a solver block. You can add your documents as add-ons and then include them with the include() function. This function automatically searches for files in the folder with extensions. This way you can update them individually. Edited by user 05 April 2023 08:32:43(UTC)
'Given' keyword also can be supported but I don't know how it will look like. Only the component has the ability to receive a set of elements on a sheet. The solution should be convenient and universal. Edited by user 05 April 2023 10:31:36(UTC)
Originally Posted by: uni Originally Posted by: Razonar Utility for call dsolvers for initial and boundary values problems from a solver block. You can add your documents as add-ons and then include them with the include() function. ... This function automatically searches for files in the folder with extensions. This way you can update them individually. Hi. That function looks great. Is there an example of using a document as an add-on? Best regards. Alvaro.
Originally Posted by: uni 'Given' keyword also can be supported but I don't know how it will look like. Only the component has the ability to receive a set of elements on a sheet. The solution should be convenient and universal. I think that SMath do not need a Given - Find block, because it have your solve block. For example, it could be used like this Best regards Alvaro.
Originally Posted by: Razonar Hi. That function looks great. Is there an example of using a document as an add-on? Try to log in here using the registration data in the program: https://en.smath.com/upload/extensions.aspxYou should see this picture: Next, you need to choose the type of extension Before uploading a file, you need to fill in the document properties. Later, you can delete the file if necessary. If the registration data is not suitable, then you need to request them from Andrey via e-mail. The registered files will be available through the gallery. Edited by user 06 April 2023 16:36:11(UTC)
on 06/04/2023(UTC), on 07/04/2023(UTC)
Plugin updated. Changes: - added support for sequence operation (sys - default, mat, line); - base frames drawing for error and eval states restored. Edited by user 17 April 2023 13:24:34(UTC)
on 17/04/2023(UTC), on 17/04/2023(UTC), on 17/04/2023(UTC)
Unfortunately, I can't reproduce your parametric plot example. It seems that the parameter range is taken from the x axis limits. Assigning a range to the parameter makes the plot fail. How to fix this? BTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension? Mathcad block.sm (14kb) downloaded 11 time(s). |
Originally Posted by: mkraska ...How to fix this? ... Use ~t instead t in list, but t in the range. Originally Posted by: mkraska BTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension? That's very original! Best regards. Alvaro.
