Joined: 27/01/2023(UTC) Posts: 30 Was thanked: 3 time(s) in 3 post(s)
I downloaded SMath Studio AppImage from the website on ubuntu 22.04. Whenever I open it, it loads that green loading box attached below then it crashes. Any help please?. Thanks in advance Edited by user 09 February 2023 01:59:33(UTC)
| Reason: Not specified
Joined: 23/07/2013(UTC) Posts: 1,131 Was thanked: 512 time(s) in 341 post(s)
Try to run with sudo. Whether appimage or regular, it won't run without sudo. Well it will, but you must try a lot of times to make it run. A link to a thread for further examinationThis is a mono bug specific to debian distros except for one. It is related with glibc and kernel version I suppose. As far as I know due to my experience, only Debian based distro I could run SMath without sudo is MXLinux (ahs). If SMath doesn't run even, please run it under a terminal. And post terminal output here, maybe it is a faulty plugin. Regards
I created account on this forum only to write that if You install in Ubuntu 22.04: libmono-cil-dev libmono-db2-1.0-cil mono-dbg mono-devel mono-tools-devel
then it should work without sudo. This is some bug within mono and installing mono debugging allows it to run apparently.
