Asked a long time ago. Unfortunately no possibility found so far to set vector arrows over letters.Only over printed documents by hand. Later changes are so hardly possible. How can I integrate the arrows into the worksheet and connect them with the letters ? Thanks for the answers
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
Originally Posted by: Oktaeder Asked a long time ago. Unfortunately no possibility found so far to set vector arrows over letters.Only over printed documents by hand. Later changes are so hardly possible. How can I integrate the arrows into the worksheet and connect them with the letters ? Thanks for the answers What you have requested is not possible by fonts itself. The ligature you asked for is called "Combining Right Arrow Above". Courier New or Liberation Mono doesn't have this. So SMath (or any program including Libreoffice, MS Word, etc) can't interpret that arrow. Only Segoe UI Symbol has that but SMath doesn't use it for functions. Yet a dirty time consuming trick may applied. Here is an example. Regards arrow above.sm (4kb) downloaded 18 time(s).
Joined: 28/08/2014(UTC) Posts: 1,361 Was thanked: 821 time(s) in 519 post(s)
Hi Oktaeder. Try copying and pasting variables from this. OverVector.sm (3kb) downloaded 19 time(s).Best regards. Alvaro.
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1127 time(s) in 723 post(s)
Overlord, you posted 4 consecutive messages just complaining about others spamming the forum. I am also annoyed by the canadian no-units cruzade and the like. Formative feedback here is waste of time. Try to avoid the impression that things get out of control. I hope you and the people you like haven't been too much affected by the horrible earthquake in your country. Edited by user 08 February 2023 20:08:34(UTC)
Originally Posted by: mkraska Try to avoid the impression that things get out of control. Whenever his spams are deleted, I delete my own. I consistently witness new users are confused by him. Just trying to avoid him doing more damage than he already did. Thanks for your kind thoughts. I am not affected nor anyone I know. But it is a devastating disaster. So many cities and people are affected.
Was thanked: 8 time(s) in 7 post(s)
Hello Overlord,
1. Is there an easy way to enter the arrow above the letter? 2. How I can enter a hat (unit vector) above a letter?
Thanks, Basile
Originally Posted by: Oktaeder Asked a long time ago. Unfortunately no possibility found so far to set vector arrows over letters.Only over printed documents You can slide any decoration over a variable name ... or over a function definition ... even an arrow !
Hello Jean,
How do you enter the arrow, Hat, etc. above such that the two are together and move together?
Basile
Originally Posted by: Basile Hello Jean, How do you enter the arrow, Hat, etc. above such that the two are together and move together? Basile You can have some circomflex hat as well from Charmap. All or most Charmap can bear function name, even single arrow. Take care Basile ... old Collab ... Jean.
You can have 'arrow(s)' as variable name Take care Basile ... Jean. BasileArrow.sm (29kb) downloaded 10 time(s).
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings, This conversation inspired me to test a few things out; apparently you can utilize a newline character within a variable name. Therefore, you don't need to 'draw' an arrow above a variable name, you can contain the arrow and the text within the variable itself! Insert arrow character(s) and insert 'newline' to type the text of the variable (to insert a new line, paste the newline character: 「\000A\」). Copy and paste the following into SMath: To make this technique more transparent, I compiled a SMath Sheet (A writer region was used to display the text \000A\ without converting it to a newline character): May this be of Good Help, - Kenny Lemens, P.E. ᵂᴵ |
1 user thanked Kenny Lemens for this useful post.
... native Charmap supports color.
