Offline Oichi
#1 Posted : 03 February 2023 01:41:33(UTC)
Oichi
Woman
Viet Nam
I saw someone here doing simulations of pendulum and other nonlinear dynamic models, I wonder how can I do that on SMath given that solutions of the ODEs is known, thanks in advance
Edited by user 05 February 2023 00:19:19(UTC)  | Reason: Not specified
#2 Posted : 03 February 2023 04:19:19(UTC)
Number of ODE's have symbolic solution.
If your DE has either of these tree forms,
Smath will spits scalar solutions wrt parameters/IC ...
One of my old baby in Mathsoft Collaboratory.
on 03/02/2023(UTC)
Offline Oichi
#3 Posted : 03 February 2023 10:20:26(UTC)
Oichi
Woman
Viet Nam
Thanks, But what I meant is how to simulate the pendulum motion itself seeing the bob and how it swings. See this link
https://en.smath.com/for...endulum-on-a-spring.aspx
Edited by user 03 February 2023 10:26:01(UTC)  | Reason: Not specified
Offline mkraska
#4 Posted : 03 February 2023 11:28:39(UTC)
mkraska
Was thanked: 1126 time(s) in 723 post(s)
In the handbook section 8.2.6 (google for kraska smath handbuch) there is an example for such animations.
The idea is to parametrize your graphics expressions with the variable t and provide a vector of values for t via context menu of the graphic area. This only works for the built-in graphics region, not for x-y plot plugin and neither for maxima.
on 03/02/2023(UTC)
Offline Oichi
#5 Posted : 03 February 2023 11:32:26(UTC)
Oichi
Woman
Viet Nam
Do you have a version that is in English?
Offline alyles
#6 Posted : 03 February 2023 14:58:41(UTC)
alyles
Google translate is your friend..
https://translate.google...p;op=translate&hl=en
Offline mkraska
#7 Posted : 03 February 2023 15:02:31(UTC)
mkraska
No, but online translators nowadays are quite powerful.
#8 Posted : 03 February 2023 15:20:45(UTC)
Ber7 demos are 6 years before I joined Smath Community.
In the mean time, you can solve the homogeneous pendulum.
ODE Pendulum Copy.sm (64kb) downloaded 5 time(s).
on 03/02/2023(UTC)
Offline Oichi
#9 Posted : 03 February 2023 20:12:17(UTC)
Oichi
Woman
Viet Nam
Finally, I did some animations, But I find some problems with the exported gifs. It acts like there are some missing frames while it's totally smooth inside the sheet.
Vibrating Pendulum.sm (16kb) downloaded 14 time(s).
Offline Razonar
#10 Posted : 03 February 2023 21:04:54(UTC)
Razonar
Uruguay
Hi. This is a workaround for that bug: https://en.smath.com/for...ot-region.aspx#post75052
However, notice that since the values of phi are numbers and not expressions, you cannot compute the derivatives of its components the way you do in D. You can check this by substituting zero for its values, and you get the same numerical solutions.
For diff(el(φ,3),t) you can use el(φ,4), and for diff(el(φ,4),t) you should use some kind of numerical estimate.
Edited by user 03 February 2023 21:06:27(UTC)  | Reason: Not specified
on 03/02/2023(UTC)
Offline Oichi
#11 Posted : 04 February 2023 00:13:12(UTC)
Oichi
Woman
Viet Nam
I tried it, but still same bug exist maybe it got lowered but its still there and thanks for making me notice that mistake, does that mean we cannot solve numerically such type of DEs without assumptions?
Edited by user 04 February 2023 00:15:03(UTC)  | Reason: Not specified
Offline Razonar
#12 Posted : 04 February 2023 00:40:30(UTC)
Razonar
Uruguay
... does that mean we cannot solve numerically such type of DEs without assumptions?
Hi Oichi. Not. Remember that given F(x,x',x'',...,t) = 0 then for using numerical DEs solvers you must to find the system D(t,x) = [x', x'', ... ] with an appropriate change of variables. Which is your original analytic expression of your differential equation to be solved? This is, the one or two equations involving both all derivatives of all "x" variables, F(x,x',x'',...,t) = 0.
Edited by user 04 February 2023 00:45:13(UTC)  | Reason: Not specified
#13 Posted : 04 February 2023 16:45:29(UTC)
This version is doctored for SS versions as low as SS 6179.
To make it compatible with ODE universal plugins.
Can you update my invented vector 'phi' in red
So that the system makes sense for all visitors.
Vibrating Pendulum (1).sm (25kb) downloaded 6 time(s).
Offline Oichi
#14 Posted : 04 February 2023 17:27:01(UTC)
Oichi
Woman
Viet Nam
This example is for a pendulum that it's upper end is attached to a spring, The displacement of this upper end is Phi(1) "u" and the angular displacement of the pendulum is Phi(2) "theta". Phi(3) "u_dot" and Phi(4) "theta_dot" are the first derivatives of the upper end vertical motion and the angular displacement of the pendulum respectively.
Edited by user 04 February 2023 17:32:52(UTC)  | Reason: Not specified
Offline Oichi
#15 Posted : 04 February 2023 21:11:46(UTC)
Oichi
Woman
Viet Nam
I did a trick and removed the d/dt terms.. but now I got a new problem. The Adams function telling me "Cannot calculate"
Vibrating Pendulum 2.sm (108kb) downloaded 6 time(s).
#16 Posted : 04 February 2023 21:21:26(UTC)
Thanks for explaining your advanced project.
Up until now, I can only manage the homogeneous Pendulum.
on 04/02/2023(UTC)
Offline Razonar
#17 Posted : 04 February 2023 23:06:12(UTC)
Razonar
Uruguay
Hi. The attached file uses the techniques shown here and here. You can also obtain the equations of motion using the lagrangian with what is shown here.
Vibrating Pendulum.sm (117kb) downloaded 13 time(s).
Vibrating Pendulum.pdf (184kb) downloaded 12 time(s).
Edited by user 04 February 2023 23:18:07(UTC)  | Reason: Not specified
on 04/02/2023(UTC)
Offline Oichi
#18 Posted : 04 February 2023 23:28:59(UTC)
Oichi
Woman
Viet Nam
Thank you so much ^^, ODEs were already obtained using Lagrangians and Hamiltonians but I did them on a paper
Guest (2)
