SMath Studio Forum
Questions
String to Variable Name (str2var)
Joined: 01/04/2020(UTC) Posts: 85 Location: Wellington Was thanked: 4 time(s) in 3 post(s)
Is there a function or method that would allow a string (or variable name) located in a matrix element to be used as the name to define a variable? Something like this: Thank you! Edited by user 31 December 2022 10:24:54(UTC)
| Reason: Not specified
4 users thanked uni for this useful post.
on 31/12/2022(UTC), on 31/12/2022(UTC), on 31/12/2022(UTC), on 01/01/2023(UTC)
Thank you so much uni! Edited by user 31 December 2022 12:49:57(UTC)
Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: marks2c Is there a function or method that would allow a string (or variable name) located in a matrix element to be used as the name to define a variable?
You can also use the Assign() function of the Maxima Plugin (this should work even without Maxima installed). It converts boolean equations into assignments. In the case of strings you still need to apply str2num() Assign.sm (5kb) downloaded 12 time(s).Edited by user 02 January 2023 13:04:16(UTC)
2 users thanked mkraska for this useful post.
on 02/01/2023(UTC), on 02/01/2023(UTC)
Some odd behavior here. When the "=" evaluation is removed the Assign() function breaks: Assign odd behaviour.sm (4kb) downloaded 1 time(s).Any thoughts? I'm hoping to be able to assign multiple variables from a matrix like this: Assign For Loop Broken.sm (6kb) downloaded 5 time(s).Edited by user 05 January 2023 02:36:10(UTC)
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
a small workaround, could be to place the for inside a line command and return a false token value, it is not very clean but it works as far as I can see. I think the assign command is not evaluated immediately, but has a delayed evaluation, which somehow only takes place after using the "=" symbol. Edited by user 05 January 2023 03:49:54(UTC)
1 user thanked churichuro for this useful post.
Originally Posted by: mkraska You can also use the Assign() function of the Maxima Plugin (this should work even without Maxima installed). Assign() is a useful function and it doesn't need Maxima as you have indicated. I don't (can't) use Maxima but I need Assign() sometimes. And its codes have zero relation with Maxima functions. This is why I suggested sometime ago that it could have relocated in another collective plugin. CustomFunctions plugin is a good candidate for this purpose. But I am not persistence, it is what it is. Author of these plugins choose it this way. Regards
Two hints: - The Assign function needs to be executed in order to do it's work, either by assigning the result to some dummy variable or by requesting display of the result. - You don't need a loop, Assign() can handle vector arguments Blatt10.sm (6kb) downloaded 3 time(s). |
Originally Posted by: overlord Originally Posted by: mkraska You can also use the Assign() function of the Maxima Plugin (this should work even without Maxima installed). Assign() is a useful function and it doesn't need Maxima as you have indicated. I don't (can't) use Maxima but I need Assign() sometimes. And its codes have zero relation with Maxima functions. This is why I suggested sometime ago that it could have relocated in another collective plugin. CustomFunctions plugin is a good candidate for this purpose. But I am not persistence, it is what it is. Author of these plugins choose it this way. Regards In general I don't care where Assign() is defined. It is in the Maxima plugin, because I needed a neat way to make use of results from Maxima functions like algebraic or ode solvers. Yet I don't think that it would be a good idea to remove functions from plugins, because this would break the dependency management of existing sheets. I don't know what happens if the same function is defined in multiple plugins. Would SMath crash? If not, which definition is used if both plugins are installed? One would see this in the dynamic help, but how to control? BTW, I think that some day I'll revisit the Maxima plugin and if I get some help with a linux development tool chain and work flow I could perhaps make the plugin work also under linux. But that would require at least two months of full time work without distractions, because I would need to learn C# anew from scratch. If someone is a master in C# I am happy to assist in refactoring and bug fixing of the plugin by providing the specifications and unit tests. I'd be more comfortable with python or javascript but to my knowledge these aren't options for making plugins. |
Hi. This could be another option. MyAssign 2.sm (11kb) downloaded 14 time(s).Best regards. Alvaro. Edited by user 06 January 2023 11:44:35(UTC)
| Reason: Example added.
7 users thanked Razonar for this useful post.
on 06/01/2023(UTC), on 06/01/2023(UTC), on 06/01/2023(UTC), on 06/01/2023(UTC), on 06/01/2023(UTC), on 06/01/2023(UTC), on 27/02/2023(UTC)
@Razonar, as usual with you, you give imaginative and useful solutions, it's great when people share their knowledge and help others, and with such a high technical level. thanks and congratulations. I have a folder on my computer exclusively for the spreadsheets you share. Edited by user 06 January 2023 22:28:08(UTC)
2 users thanked churichuro for this useful post.
on 06/01/2023(UTC), on 07/01/2023(UTC)
Joined: 23/03/2016(UTC) Posts: 277 Was thanked: 91 time(s) in 57 post(s)
3 users thanked alyles for this useful post.
on 06/01/2023(UTC), on 07/01/2023(UTC), on 07/01/2023(UTC)
Originally Posted by: churichuro @Razonar, as usual with you, you give imaginative and useful solutions, it's great when people share their knowledge and help others, and with such a high technical level. thanks and congratulations.
I have a folder on my computer exclusively for the spreadsheets you share. Yes indeed. Likewise. What churichuro said!
1 user thanked marks2c for this useful post.
Thanks guys. I sincerely appreciate that.
SMath Studio Forum
Questions
