Hello I can't install several plugins, see attached image Best Regards Carlos
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Hello Carlos, I have no such problem. Hope somebody will help you. |
Hello NDTM
Thank you very much, I also hope that someone can solve the problem, which seems to be something that always occurs in updates.
Carlos
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1338 time(s) in 878 post(s)
It depends on the implementation of the interfaces between the program and the plugins, although I'm not sure why sometimes the plugin don't work for someone; usually is enough to recompile the plugin, sometime the code has also to be updated. |
