Joined: 23/11/2018(UTC) Posts: 4   Was thanked: 5 time(s) in 1 post(s)
This plug-in can perform beam analysis using Euler-Bernoulli Beam Theory (using dofs v and θz only): 1.) It can draw load diagram, shear, moment, slope and transverse deflection diagrams using 2-D plots. Plots don't need to be scaled when results or beam length changes. 2.) You can add Supports of "PIN", "FIXED", Vertical Spring, and Rotation Spring Supports. 3.) You can add specified transverse deflection and/or rotation 4.) You can define point loads, linearly distributed transverse loads 5.) You can get reactions, internal shear and moments as well as slope and deflection at any location or query maximum/minimum results withing a specified range location. 6.) You can define load cases and solve certain load case or combinations 7.) SectionPropertyAISC function included - based on AISC shape database v15 This plugin is best used for structural engineering calculations such as Beam Design. This was inspired by Beam Analysis Utility Functions plugin and WinBeam program. You can view all the FEBeam functions by going to Insert > Functions or by downloading these sample smath worksheets Example worksheets: FEBeam Sample Smath 1.sm (114kb) downloaded 96 time(s). FEBeam Sample Smath 2.sm (34kb) downloaded 70 time(s). FEBeam Sample Smath 3.sm (154kb) downloaded 65 time(s).Snapshots:  Edited by moderator 12 December 2022 12:55:58(UTC)
| Reason: Not specified
 5 users thanked JC Mendoza for this useful post.
on 11/12/2022(UTC), on 12/12/2022(UTC), on 12/12/2022(UTC), on 12/12/2022(UTC), on 12/12/2022(UTC)
Joined: 28/08/2014(UTC) Posts: 1,166  Was thanked: 679 time(s) in 424 post(s)
Hi JC. Thanks, very useful. Just as very marginal comment, you can improve how to show the extrema results. Instead of write the results, you can automate that in various forms. For example, hiding the input data, like this or using the table plugin  Best regards. Alvaro.
Originally Posted by: Razonar  Hi JC. Thanks, very useful. Just as very marginal comment, you can improve how to show the extrema results. Instead of write the results, you can automate that in various forms. For example, hiding the input data, like this or using the table plugin  Best regards. Alvaro. Hi Alvaro, Yeah it is better to put results in table format  Thanks for this. Best Regards, JC
Joined: 23/07/2013(UTC) Posts: 988  Was thanked: 407 time(s) in 274 post(s)
Unfortunately doesn't work under linux (mono).
Originally Posted by: overlord  Unfortunately doesn't work under linux (mono). Hello, I haven't really used linux..I might need help with this one.. PS: I'm not hardcore programmer..I just learned to code because it was a requirement on my schooling in engineering..I also just followed the programming patterns on how to create plugin from other plugins on SMath SVN  Edited by user 13 December 2022 09:21:20(UTC)
