I've noticed that no one else has reported this publicly. It happens quite often. I try to access the Smath Studio website, and I get timeouts. Also, my name often turns yellow in the program (top-right corner by the Minimize/Maximize/Close button) at the exact same time, and I can't update plugins, showing that it's on your end. What's causing it to go down? It happens more in the morning and early afternoon (my local time) than in the evening.
Joined: 02/06/2010(UTC) Posts: 6 Location: Italy Was thanked: 1 time(s) in 1 post(s)
I can say that in Italy I never experienced problem like yours
Originally Posted by: Stargate38 I've noticed that no one else has reported this publicly. It happens quite often. I try to access the Smath Studio website, and I get timeouts. Also, my name often turns yellow in the program (top-right corner by the Minimize/Maximize/Close button) at the exact same time, and I can't update plugins, showing that it's on your end. What's causing it to go down? It happens more in the morning and early afternoon (my local time) than in the evening. I am in US as well. I can't say that I've had this issue. Perhaps issue with your ISP or DNS? |
Up there, Smath Forum works charmingly well.
Sometimes, not often but very rarely, I come across this too. However, I think problem is not SMath server. I suspect my ISP.
When it happens you can check if it is a site problem with external services like this. If the site is up for the others then you can try to catch where is the issue with a "tracert smath.com" in a command prompt. |
