2 Pages<12
Offline ola_nicolas
#21 Posted : 11 July 2022 20:29:59(UTC)
ola_nicolas
Romania
Greetings Jean Giraud. I mean by "analytic", to write a function "func (arg)" using strictly the functions defined in smath (other than "Clear (arg)"Wink whose result is identical to that provided by the predefined function in smath "Clear (arg)"
Edited by user 11 July 2022 20:37:26(UTC)  | Reason: Not specified
#22 Posted : 11 July 2022 23:53:36(UTC)
Analytical function(s) are function(s) that you can:
derive, integrate, Laplace, Fourier, else transform ... etc.
Clear(▪,▪,▪, ...) simply evaporates the collection.
What you can do: front end a program by Clear(▪,▪,▪, ...)
If your program is analytical, de-facto Clear is analytical,
that is for twisted mind... glass ½ full/empty.
#23 Posted : 12 July 2022 16:49:30(UTC)
Once the vector 'x' has been cleared ▼ internally
'x' is free for analytic/numeric function(s)...
If that's what you mean by analytic Clear(,)
If you have comments or more in mind ... welcome.
Maths Clear.sm (23kb) downloaded 13 time(s).
Offline ola_nicolas
#24 Posted : 13 July 2022 23:04:50(UTC)
ola_nicolas
Romania
... Clear(▪,▪,▪, ...) simply evaporates the collection ...
OK. Then why doesn't this function exist in MathCAD - at least until MathCAD 14, which I use. In fact, that would be the basic idea. How do I synthesize such a function in MathCAD, a function that I often miss ?!
Edited by user 13 July 2022 23:13:09(UTC)  | Reason: Not specified
#25 Posted : 14 July 2022 17:08:06(UTC)
Mathcad 14 was a freak. Saved as 11 ... back 11 was Christmas decoration !
At Mathsoft home, my MCD 11 crashed Mona MCD 14.
Mathcad 11 was a semi-compiled CAS, much different than Smath Plugins.
In Mathcad 11 and earlier, variables, data don't reside, nothing to Clear.
If 'x' has been ranged above and next you want the symbolic wrt 'x'
x:= ▪
it shows the place holder, then evaporated, free for symbolic.
Don't hesitate for more ... Jean.
Offline ola_nicolas
#26 Posted : 20 July 2022 11:49:08(UTC)
ola_nicolas
Romania
OK. Many thanks Jean Giraud
Offline Kenny Lemens
#27 Posted : 28 February 2023 01:23:16(UTC)
Kenny Lemens
Was thanked: 62 time(s) in 39 post(s)
Greetings,
Another solution was just posted as a worksheet example, located here: https://en.smath.com/for...a-formula.aspx#post80591
As an additional observation to this whole topic, I achieved sufficient success if I did the following (without the need for a plugin or special functions):
  1. defining the equations before declaring any of the variables
  2. defining the variables and display evaluation immediately (optimization=NONE)
  3. display the equation, define optimization=NONE
  4. Final: display the equation, define optimization=numeric
Depending on your circumstance, utilizing Symbolic evaluation and calling the function Eval() may be in your best interest.
Hope this helps;
Kenny Lemens, P.E. ᵂᴵ
thanks 2 users thanked Kenny Lemens for this useful post.
on 28/02/2023(UTC),  on 28/02/2023(UTC)
2 Pages<12
