Offline Ioan
#1 Posted : 16 September 2012 23:32:13(UTC)
Ioan
Rank: Member
France, Metropolitan
Hi Andrey,
Here attached I have an other case where the symbolic optimisation gives a completely false results.
Hoping to serve for yours futures improvements.
Best regards,
Ioan
File Attachment(s):
rotsys.sm (23kb) downloaded 32 time(s).
Offline mkraska
#2 Posted : 17 September 2012 18:34:42(UTC)
mkraska
Hello
The function norme(v) is buggy (known issue in the forum). Use sqrt(v^2) instead if v is a single column as in your example. Works with both numeric and symbolic optimization.
Best regards, Martin Kraska
Offline Ioan
#3 Posted : 17 September 2012 20:18:38(UTC)
Ioan
Rank: Member
Hello Martin,
Thanks for your answer.
I replaced all norme(v) as you suggest (see attached file) and for case of symbolic optimisation the results are still wrongs (?).
Best regards,
Ioan
File Attachment(s):
rotsys2.sm (28kb) downloaded 20 time(s).
Offline mkraska
#4 Posted : 18 September 2012 02:29:32(UTC)
mkraska
Hello Ioan,
ok, you are right. Replacing enorm is not sufficient to solve the problem. There is another one with trig operations. The problem is that sin(θ) is symbolically evaluated to zero, whereas the correct value is sqrt(2)/sqrt(3). If you ask SMath to simplify sin(acos(a)) you get sin(acos(a))=sqrt(1-a^2). If you use that instead of sin(θ) :
RSadidentity(3)+sqrt(1-({v.f*v.i}/{sqrt(v.f^2)*sqrt(v.i^2)})^2)*mat(0,-el(p,3),el(p,2),el(p,3),0,-el(p,1),-el(p,2),el(p,1),0,3,3)+(1-cos(θ))*(p*transpose(p)-identity(3)))
then you get the correct symbolic result.
R=mat(-{1-sqrt(3)}/{2*sqrt(3)},{1+sqrt(3)}/{2*sqrt(3)},1/sqrt(3),{1+sqrt(3)}/{2*sqrt(3)},-{1-sqrt(3)}/{2*sqrt(3)},-1/sqrt(3),-1/sqrt(3),1/sqrt(3),-1/sqrt(3),3,3)
Symbolic evaluation seems to be not really reliable. Simplifications are not done even if SMath is well aware of that they could be done.
An example is
cos(θ)={mat(0,0,-1,3,1)*mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)}/{sqrt(mat(0,0,-1,3,1)^2)*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)}
which is not simplified although the following works:
{mat(0,0,-1,3,1)*mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)}/{sqrt(mat(0,0,-1,3,1)^2)*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)}=-1/sqrt(3)
Also, if sin(acos(a))=sqrt(1-a^2) then the following cannot be correct:
sin(θ)=sqrt({sqrt(mat(0,0,-1,3,1)^2)^2*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)^2-1}/{sqrt(mat(0,0,-1,3,1)^2)^2*sqrt(mat(1/sqrt(3),-1/sqrt(3),1/sqrt(3),3,1)^2)^2})
Here, perhaps the symbolic engine tries to apply the square to the dot product by applying the square to the factors individually. This yields 1 because both vectors are unit vectors. It might be correct for scalars but definitely not for vectors. BTW it does not help to use matrix formulation of the dot product el(transpose(v)*v,1). We had such issues already with SMath assuming matrix multiplication to be commutative.
By the way, instead of your special function you could write v.i†v.f=mat(1/sqrt(3),1/sqrt(3),0,3,1).
Offline Ioan
#5 Posted : 18 September 2012 09:29:56(UTC)
Ioan
Rank: Member
Hello Martin,
Thanks a lot for your useful analysis.
Best regards,
Ioan
Offline mkraska
#6 Posted : 20 October 2012 12:27:08(UTC)
mkraska
here is one more example for incomplete symbolic simplification in trig context. SMath knows that sin(30° ) equals 1/2 but can't find out symbolically that cosec(30° )=1/sin(30° ) is 2.
Edited by user 20 October 2012 12:32:40(UTC)  | Reason: Not specified
File Attachment(s):
trig.sm (10kb) downloaded 12 time(s).
Offline Geraldinehenry
#7 Posted : 22 October 2012 08:42:00(UTC)
Geraldinehenry
Location: 212 Jackson Ave,Warren, Pennsylvania,United States
Wow, so difficult to me:'(
