Was thanked: 76 time(s) in 57 post(s)
Hello The unit operation snippet fails to detect units.  Snippet_Units_Fail.sm (34kb) downloaded 17 time(s).Best Regards Carlos
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,618   Location: Italy Was thanked: 1322 time(s) in 872 post(s)
Joined: 04/07/2015(UTC) Posts: 6,800  Was thanked: 975 time(s) in 803 post(s)
Originally Posted by: CBG  The unit operation snippet fails to detect units. Hola Carlos ... Jean... OK SS 6179
Hello David Thank you very much for your answer, but the snippet fails, since instead of finding the units, it only obtains the value of 1  Hola Jean Saludos Best Regards Carlos
My bad, IDK why but yesterday seemed to work to me, but in fact it doesn't. I'll give another look at the snippet ASAP. |
I see the issue. The function look for a numerator/denominator pattern in the num2str() text, but doesn't handle cases in which multiple divisions are involved. Edited by user 18 May 2022 20:18:43(UTC)
Hello David Thank you very much for your attention, I hope the Snippet has a fix- On the other hand, I ran the snippet in version 6179, and it works perfectly. How is that possible?  Best Regards Carlos
I'm not sure, however if you need a urgent fix here you have an easy way to make it working the same way. ![2022-05-19 13_24_54-SMath Studio 0.98.6179 - [Documento1_].png](/forum/resource.ashx?a=43788&b=2) Edited by user 19 May 2022 20:29:37(UTC)
