2 Pages12>
Offline johnpan
#1 Posted : 11 May 2022 06:02:05(UTC)
johnpan
Rank: Member
China
Hi, Guys:
I'm using FindRoot for SOE solution,but something make me confusion. for example:
the same SOE with different variables, different result, and the second is wrong.
I think maybe I have something wrong. please help me, how to use the FindRoot?
Thanks a lot!
John
attach the file
soe.sm (7kb) downloaded 6 time(s).
Offline Razonar
#2 Posted : 11 May 2022 06:24:23(UTC)
Razonar
Uruguay
Was thanked: 542 time(s) in 352 post(s)
Hi. You must to sort the variables in the same order than Unknowns.
on 11/05/2022(UTC)
Offline johnpan
#3 Posted : 11 May 2022 07:49:05(UTC)
johnpan
Rank: Member
China
Hi, is there any rules for the order?
Thanks alot
John
Offline Razonar
#4 Posted : 11 May 2022 09:32:40(UTC)
Razonar
Uruguay
Hi. You can't redefine Unknowns. Well, you can, but isn't the best idea. Unknowns is a function in the same plugin than FindRoots, SpecialSolvers. I don't know the internals of the plugin. My guess that the general rule is sort the variable names in lexical order, but if the name has unicode characters or some unusual ASCII character, it is best to make sure of the order to follow by evaluating Unknows(eq).
Offline johnpan
#5 Posted : 11 May 2022 11:30:29(UTC)
johnpan
Rank: Member
China
okay, I got it. but a new question, why I can't got the result as your picture?
would you mind post the sample sm file ?
Thanks a lot!
John
Edited by user 11 May 2022 11:33:01(UTC)  | Reason: Not specified
Offline Razonar
#6 Posted : 11 May 2022 12:22:01(UTC)
Razonar
Uruguay
SMath have two "=": Numerical and Symbolical. With numerical evaluation you can only obtain numerical values, that is, without undefined variables. Rigth click to change it to symbolic equals, or use Ctrl+period instead "=", or click symbolic evaluation in the right panel.
Sorry, I forgot to post it, and right now can't.
Offline johnpan
#7 Posted : 11 May 2022 12:36:21(UTC)
johnpan
Rank: Member
China
Clap
thank you!
I got it.
Thanks a lot!
John
#8 Posted : 11 May 2022 14:31:04(UTC)
Was thanked: 891 time(s) in 719 post(s)
OBSERVE ... so much from so little
Solve Algebraic, NON-Algebraic Read first.sm (70kb) downloaded 6 time(s).
#9 Posted : 11 May 2022 14:56:57(UTC)
This multi solve companion is 3 x 3
Make it 2 x 2 ... n x n ... as per your project.
Solve Algebraic, MULTISOLVE Companions.sm (18kb) downloaded 8 time(s).
Online overlord
#10 Posted : 11 May 2022 21:32:03(UTC)
Turkey
Was thanked: 276 time(s) in 196 post(s)
You can automate assigning guesses to unknowns.
By this way, you won't care order of them.
findroot_auto.sm (5kb) downloaded 16 time(s).
thanks 2 users thanked overlord for this useful post.
on 11/05/2022(UTC),  on 12/05/2022(UTC)
#11 Posted : 12 May 2022 14:44:12(UTC)
For your example, make it algo style for local infinite use.
Observe ... sols:=U^-1*V is universal outside of Smath Plugin(s)
... your question about order of vars
solutions are by convention in descending order of the pair wise u, v
no matter the names you give.
I can't explain the decimals difference between MCD 11/Smath.
There are other constants that can't be found exactly ...
Pitot constant, Goat radius constant ...
That remark applies to any solvers [Smath and wrt any CAS]
The U^1*V is the core component of the Cholesky solver
as applied to fitting model function to a data set.
In that case, best fit is obtained by iterating the Genfit.
Chers ... Jean.
#12 Posted : 12 May 2022 15:46:19(UTC)
... here, you can push the cork in the bottle to accommodate irrational pi.
as well ignore epsilon.
#13 Posted : 12 May 2022 16:11:31(UTC)
... as it looks, the max I could push the cork in the bottle
y≡0.279339266990994 ... sanity f(x,y,z)=-0.000000000001344
Confirms impossible exactly solving irrational numbers.
Online overlord
#14 Posted : 13 May 2022 00:51:29(UTC)
Turkey
Long word short, there is an order for vars.
You can either avoid it manually or automatically.
It is up to users choice which suits them most.
Either one has advantages over other.
Offline johnpan
#15 Posted : 15 May 2022 14:04:08(UTC)
johnpan
Rank: Member
China
Thank you all so much!
a nice forum Good
Offline churichuro
#16 Posted : 15 May 2022 17:21:14(UTC)
churichuro
Mexico
Was thanked: 16 time(s) in 14 post(s)
I never thought the time would come when I would become an expert at ignoring specific comments on a forum...thanks Jean! Dry
thanks 1 user thanked churichuro for this useful post.
on 16/05/2022(UTC)
#17 Posted : 15 May 2022 19:20:51(UTC)
Thank you all so much !
Solving is very important in Engineering Projects.
Reserve ... solve, roots, FindRoots and more to specific applications
Solving a square matrix goes via the conventional solver, no flaw.
This didactic document has been refreshed.
Solve Algebraic, MULTISOLVE DIDACTIC.sm (22kb) downloaded 11 time(s).
#18 Posted : 15 May 2022 21:26:39(UTC)
...Thanks Jean!
Many of the advanced Smath documents are join venture.
Adapted/exemplified from various sources.
Download: Samples, Utilities Most used_3.
If something is not clear, please don't hesitate.
You have more, please offer.
Take care Amigo ... Jean.
Online overlord
#19 Posted : 15 May 2022 21:34:46(UTC)
Turkey
No churichruo, dont.
If you will post same worksheets 600 times, (satire here)
and then you will tease how less another one contributed,
and how your post statistic is 18.3% of entire forum,
Please don't.
You will just make a fool of yourself.
on 16/05/2022(UTC)
#20 Posted : 16 May 2022 16:35:46(UTC)
Do you mean churichruo will make a fool of himself
from reputed contributors in this document:
Mathsoft, Robert Adair, Carlos, Martin, Viacheslav, Romberg,
Riemann FD, Hermite Polyline, Legendre, Gram_Schmidt,
Guiseppe Borzi [simplex], Mathsoft Collaboratory Convolution ...
I will add Fresnel [Clothoid].
churichruo wrote Tanks Jean
2 Pages12>
