Offline ndtma
#1 Posted : 14 April 2022 13:52:18(UTC)
ndtma
Sri Lanka
Was thanked: 125 time(s) in 82 post(s)
At present, my country Sri Lanka is undergoing its worst crisis since its independence in 1948, with severe shortage of essential items like fuel, cooking gas, electricity, medicine, milk and food items. As a result, we are compelled to be at home, while thousands are protesting in the capital city of Colombo and other major cities.
So, during this period I spent some time on SMath, and attempted the attached example in the internet solved by Hardy Cross Method using EXCEL
Essentially it is an overdetermined nonlinear pipe network with 22 variables {pipe flows) and 23 equations (16 Nodes + 7 Loops). The solution using SMath is based on a snippet using al_nleqsolve() posted by Viacheslav N. Mezentsev (uni) in SMath Forum.
Overdetermined_Nonlinear_Pipe_Network.pdf (433kb) downloaded 77 time(s).
Overdetermined_Nonlinear_Pipe_Network.sm (630kb) downloaded 80 time(s).
Edited by user 14 April 2022 13:55:31(UTC)  | Reason: Not specified
thanks 4 users thanked ndtma for this useful post.
on 14/04/2022(UTC),  on 14/04/2022(UTC),  on 14/04/2022(UTC),  on 12/06/2022(UTC)
Offline Ber7
#2 Posted : 14 April 2022 15:40:58(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Hello,ndtma
Fragments withal_nleqsolve() can be reduced to one line.
alnlegsolve(3).sm (636kb) downloaded 47 time(s).
Edited by user 14 April 2022 15:44:56(UTC)  | Reason: Not specified
thanks 1 user thanked Ber7 for this useful post.
on 14/04/2022(UTC)
Offline ndtma
#3 Posted : 14 April 2022 16:03:58(UTC)
ndtma
Sri Lanka
Originally Posted by: Ber7 Go to Quoted Post
Hello,ndtma
Fragments withal_nleqsolve()can be reduced to one line.
Hello Ber7,
Thank you very much for your very valuable suggestion.
It works fine.
Offline Razonar
#4 Posted : 15 April 2022 02:33:11(UTC)
Razonar
Uruguay
Hi Nugegodage. I hope that the problems in your country can be solved, for the better, and that you and your family are well.
Thank you for this excellent example.
Your worksheet with a little different setup, using tables. No one new calc actually.
alnlegsolve v2.sm (905kb) downloaded 59 time(s).
on 15/04/2022(UTC)
Offline CBG
#5 Posted : 15 April 2022 05:09:43(UTC)
CBG
Hello Nugegodage
I hope that you and your family are very well in these times of crisis in your country.
I have made your example in the Epanet program, the results are shown in the graph below.
For the network to be valid, Node A must have an input pressure equal to or greater than 129.4 mH2O,
and Node C equal to or greater than 150.28 mH2O.
Carlos
thanks 1 user thanked CBG for this useful post.
on 15/04/2022(UTC)
Offline ndtma
#6 Posted : 15 April 2022 06:33:25(UTC)
ndtma
Sri Lanka
Hi Jean, Alvaro, Carlos and others.
Thanks for expressing your sentiments and encouragement.
We are safe and hope the situation will settle as early as possible.
Many thanks to Alvaro and Carlos for your suggestions on the example.
Offline overlord
#7 Posted : 17 April 2022 14:43:24(UTC)
Turkey
Thanks for your sample.
I always like your irrigation examples.
Hope crisis in your country resolves too.
Offline ndtma
#8 Posted : 17 April 2022 16:47:27(UTC)
ndtma
Sri Lanka
Hi overlord.
Thank you for the sentiments and comments.
Offline ndtma
#9 Posted : 26 May 2022 10:38:30(UTC)
ndtma
Sri Lanka
The subject revisited.
In my original post #1, the K values were simply computed using a given formula,
and head loss in each pipe computed accordingly.
In Method 1 of the attached example, friction factors (f) depend on the Reynold numbers (Re)
of each pipe and computed using a given formula involving Re.
In Method 2, NewtonRapson function of SMath is used for the numerical solution of the
implicit Colebrook-White equation to find f.
Many thanks to Ber7, Alvaro and Carlos for your earlier suggestions on the subject.
Overdetermined_Pipe_Network_3 LOOPS-As per CHEGUIDE_al_nleqsolve.sm (287kb) downloaded 53 time(s).
Overdetermined_Pipe_Network_3 LOOPS-As per CHEGUIDE_al_nleqsolve.pdf (582kb) downloaded 32 time(s).
Edited by user 26 May 2022 11:11:11(UTC)  | Reason: Not specified
Offline CBG
#10 Posted : 30 May 2022 05:06:37(UTC)
CBG
Hello ndtmda
Here are the results of your example calculated
with a very old version of Pipe Flow Expert.
Carlos
Offline ndtma
#11 Posted : 30 May 2022 11:19:26(UTC)
ndtma
Sri Lanka
Originally Posted by: CBG Go to Quoted Post
Hello ndtmda
Thank you Carlos!
Offline ndtma
#12 Posted : 06 June 2022 09:23:10(UTC)
ndtma
Sri Lanka
Hello Carlos
Can you please explain how the marked values of gauge pressures are calculated?
Thank you.
Offline CBG
#13 Posted : 07 June 2022 05:31:51(UTC)
CBG
Hello Ndtma
Originally Posted by: ndtma Go to Quoted Post
Hello Carlos
Thank you.
This pressure (0.9787 bar g) is caused by the water level in the tank, which is 10 meters.
The pressure of 0.6553 bar g is obtained by subtracting from the inlet pressure
of 0.9787 bar g. the losses in the pipe of 0.3234 bar g (3.304 m hd)
The system is not correctly resolved for the pressures, since nodes 3 and 8 have
pressures below atmospheric.
Carlos
Edited by user 07 June 2022 05:37:33(UTC)  | Reason: Not specified
on 08/06/2022(UTC)
Offline ndtma
#14 Posted : 07 June 2022 06:17:56(UTC)
ndtma
Sri Lanka
Thank you Carlos.
Offline CBG
#15 Posted : 07 June 2022 23:20:35(UTC)
CBG
Hello Ndtma
Thank you Carlos.
You're welcome.
Changing the diameter of tubes 9 and 10 from 0.25 m diameter to 0.5 m, the problem of negative pressures is solved.
Another way to solve it is by increasing the level below the tank from 0m to 20m. and with the liquid level at 10 m
Carlos
on 08/06/2022(UTC)
Offline ndtma
#16 Posted : 08 June 2022 04:55:01(UTC)
ndtma
Sri Lanka
You're welcome.
Thank you Carlos. Your contributions are very much appreciated.
Offline ndtma
#17 Posted : 11 June 2022 06:26:18(UTC)
ndtma
Sri Lanka
You're welcome.
Hello Carlos,
Can you please post the Pipe Data Table (with Pipe Number, Inner diameter, ..... Re, Friction Head loss)
for the case Changing the diameter of tubes 9 and 10 from 0.25 m diameter to 0.5 m..
as I get different results for this case.
Hope I am not troubling you.
Edited by user 11 June 2022 06:29:25(UTC)  | Reason: Not specified
Offline CBG
#18 Posted : 11 June 2022 22:19:34(UTC)
CBG
Hello Ndtma
Hello Carlos,
There is no problem.
Here is the requested table
Carlos
on 12/06/2022(UTC)
Offline ndtma
#19 Posted : 12 June 2022 04:27:18(UTC)
ndtma
Sri Lanka
Thank you very much Carlos.
Guest (2)
