Offline Mario Acevedo
#1 Posted : 12 April 2022 22:14:10(UTC)
Mario Acevedo
Rank: Member
Mexico
Dear all:
I am new to Smath Studio, great software!
Even I am new to its usage, I am trying quite complicated calculations I guess.
I am putting the following lines:
As you can see, I am using Maxima plugin and the Maxima function ev() to substitute values in the symbolic variable. I have some specific questions:
1.) Is there an alternative way to do this kind of calculations without using the Maxima plugin?
2.) v is a system of values, each value is an equality, is there an automatic way to generate a system of values?
Thank to all the people that could help.
Edited by user 13 April 2022 01:37:09(UTC)  | Reason: Not specified
Offline mkraska
#2 Posted : 12 April 2022 23:04:06(UTC)
mkraska
I can't open your image. From what you describe, you might want to use the substitution function at() from Custom Functions plugin.
at.sm (23kb) downloaded 18 time(s).
#3 Posted : 13 April 2022 00:16:56(UTC)
Attach your Smath document.
#4 Posted : 13 April 2022 00:51:35(UTC)
#5 Posted : 13 April 2022 01:41:47(UTC)
Mario Acevedo
Rank: Member
Mexico
Sorry about the image, now the image is visible.
What I want is to iterate over a set o values to substitute in a variable a store the results in a variable, something like this:
Is there a way to do this substitutions in an iterative way?.
I mean: using a set of programming lines?
In this worksheet I copied and pasted the lines to perform the iterations, but in a general problem solving it is desirable to iterate automatically.
Edited by user 13 April 2022 02:06:57(UTC)  | Reason: Not specified
#6 Posted : 13 April 2022 02:20:21(UTC)
Mario Acevedo
Rank: Member
Mexico
Here is the Worksheet:
Worksheet1.sm (11kb) downloaded 8 time(s).
#7 Posted : 13 April 2022 02:45:20(UTC)
Mario Acevedo
Rank: Member
Mexico
Thank you Martin Kraska, at works fine and is what I needed.
It seems that to iterate I have to declare the sys vector by myself, isn't it?
Thanks a lot!
#8 Posted : 13 April 2022 03:29:50(UTC)
An iterative process is a solving process.
As you say, you just want to plug something from command line.
#9 Posted : 13 April 2022 05:45:16(UTC)
Mario Acevedo
Rank: Member
Mexico
wow!, this is what I was looking for!!!, THANK YOU very much Jean Giraud!
Offline PompelmoTell
#10 Posted : 13 April 2022 13:41:58(UTC)
PompelmoTell
I take inspiration from Jean, but I use the Vectorize function and I forget the size of U
FunzioniVettori.sm (7kb) downloaded 11 time(s).
Offline MarB
#11 Posted : 13 April 2022 14:21:09(UTC)
MarB
Pay attention! The definition of M(r) doesn't make much sense.
#12 Posted : 13 April 2022 14:41:51(UTC)
Superb Sergio ... added in the main document.
Offline overlord
#13 Posted : 13 April 2022 15:48:44(UTC)
Turkey
Was thanked: 510 time(s) in 340 post(s)
An algorithm can also be used.
It may be simpler by this way.
Worksheet1_algorithm.sm (5kb) downloaded 9 time(s).
#14 Posted : 13 April 2022 20:10:35(UTC)
Mario Acevedo
Rank: Member
Mexico
Nice implementation!!
Just a question, does the S variable had to be declared and dimensioned previous to its use?
I will try the code asap!
Thank you !
Offline MarB
#15 Posted : 13 April 2022 20:48:08(UTC)
MarB
You should always define variables used as arrays in function before assigning elements.
Worksheet1_algorithm.sm (9kb) downloaded 5 time(s).
thanks 1 user thanked MarB for this useful post.
on 13/04/2022(UTC)
#16 Posted : 13 April 2022 22:04:10(UTC)
Just a question, does the S variable had to be declared and dimensioned previous to its use ?
No, it sets by itself within the for loop.
Wise to clear within the algo ... U:=0
That will avoid interaction with else U above document.
Algo style is an immense companion in Smath.
Personally, I use it as much as possible,
it enables the local command line.
Maths algo style MATRIX in_extenso.sm (6kb) downloaded 1 time(s).
Offline overlord
#17 Posted : 13 April 2022 22:47:50(UTC)
Turkey
MarB is dead right.
Array variables should be considered carefully if they will be redefined multiple times.
Or they can be undefined and named uniquely. I tend to name variables in functions this way.
You can find below how I would name your functions variables.
Pretends mess of misusage.
#18 Posted : 13 April 2022 23:55:24(UTC)
It isn't required but it is good practice. If the variable name already exists you might fall in some unexpected cases when the dimensions are different. In addition to the above suggestions, you can use also a Clear(S) as initializer.
Guest (2)
