Offline marks2c
#1 Posted : 10 April 2022 07:57:45(UTC)
marks2c
New Zealand
Was thanked: 4 time(s) in 3 post(s)
As I'm learning into SMath (and greatly enjoying this) I've struck a wee problem and I can't seem to find in the tool pallets or the interactive book/help videos.
It is the Vertical Bar operator (constraint? inputs?) and how do I enter it?
Thank you in advance.
Offline overlord
#2 Posted : 10 April 2022 11:49:49(UTC)
Turkey
Was thanked: 510 time(s) in 340 post(s)
It is line() function.
on 10/04/2022(UTC)
Offline marks2c
#3 Posted : 10 April 2022 12:22:16(UTC)
marks2c
New Zealand
Excellent, thank you. On to it.
#4 Posted : 10 April 2022 16:45:51(UTC)
Type ]
to elongate: click any place holder, type ,,,,,, coma
Try it, does it work ? Much simpler than from f(x) menu.
Offline Ber7
#5 Posted : 10 April 2022 20:05:43(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
No function line()
Primer.sm (7kb) downloaded 5 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 11/04/2022(UTC)
Offline overlord
#6 Posted : 11 April 2022 06:30:57(UTC)
Turkey
Line() is used mainly for programming.
One benefit of using is using in user functions.
You can find more information about other things on Reference book.
Cilck to enlarge
on 11/04/2022(UTC)
Offline mkraska
#7 Posted : 11 April 2022 12:51:49(UTC)
mkraska
In Appendix B of the SMath Handbuch you find a list of operators and how to input them.
There is also a snippet "Help" in the online gallery but some entries there are not correctly formatted (problem with Table region).
In the interactive handbook you find these tables under >SMath Studio Documents >Operators and their keyboard input.
The tables there seem to be ok. There seem to be differences between the rendering engine in the reference material window and in the main window of SMath Studio.
Edited by user 11 April 2022 12:59:13(UTC)  | Reason: Not specified
on 11/04/2022(UTC)
#8 Posted : 11 April 2022 15:30:31(UTC)
Your very first project may produce an arc region
as exemplified/demo in the attached ... NFG for suite.
As offered, no flaw ...
However, new command line dictates the suite be adapted.
Smath so gorgeous in there !
Maths algo style.sm (44kb) downloaded 5 time(s).
#9 Posted : 11 April 2022 16:42:00(UTC)
Here, there is no tool palette.
Immensely productive.
Offline overlord
#10 Posted : 11 April 2022 20:21:06(UTC)
Turkey
There are some other tricks to remember as well.
Here is list of would be considered useful;
  • symbolic/numeric optimization
    most errors can be parsed with selecting the right one
  • Δ temperatures (Δ°C, Δ°F, Δ°Re)
  • using units for engineering calculations
  • not using units for plots and some solvers {solve(), roots()}
    or using multiplications at right place to trick as value is unitless
  • using maple() or maxima() for most symbolic results (better support)
  • smath vectors/matrices starts with 1, mathcad starts with 0
    some new users troubles with converting mathcad functions to smath
  • recursive functions shall give an error after 50 steps
    better not to use it, try to write algorithms conventional way
  • eval() for faster calculations (sometimes)
  • line() for verbatim functions (not needed always)
  • to be careful for variable names
  • choosing right plot for the right job
on 11/04/2022(UTC)
#11 Posted : 12 April 2022 14:35:59(UTC)
... slightly refreshed.
Maths algo style.sm (47kb) downloaded 7 time(s).
#12 Posted : 13 April 2022 02:13:42(UTC)
Offline overlord
#13 Posted : 13 April 2022 12:28:14(UTC)
Turkey
Sometimes eval() and line() can correct the solutions too.
SMath may have difficulties and those two may help.
