Offline Valentino
#1 Posted : 30 March 2022 16:20:10(UTC)
Valentino
Rank: Member
Mexico
Was thanked: 7 time(s) in 3 post(s)
Hi, it's me again XD
I try to find the value of a temperature that when replacing it in an equation the result is 0 KJ/Kg. I have already done things like this, where I propose a temperature or pressure and with the "Root" or "Solve" command I get the result, however this time I am using CoolProp instead of equations of state and polynomials, I don't know if that affects, you know by the units and things like that... does anyone know how to do it?
I already tried with a mathcad solve block although I think I'm not using it well, approximately the temperature is around 294.2 K, it would be great if this can be done with a "Root", "Solve", or "FindRoot" so as not to have to do it with a Newton Raphson
thank you very much for reading me
Cooling Towers with SMath Studio E1.sm (66kb) downloaded 20 time(s).
Offline Razonar
#2 Posted : 30 March 2022 20:12:50(UTC)
Razonar
Uruguay
Was thanked: 834 time(s) in 528 post(s)
Hola Valentino. The nonlinear plugin solvers don't work because they can't get the derivative of the function. SMath's diff function does not work on functions defined in plugins, in this case coolprop. You can see that in this post: https://en.smath.com/for..._postst12504_Uneval.aspx
To get the root you need to implement your own pure numerical solver or use al_nleqsolve.
Cooling Towers with SMath Studio E1.sm (70kb) downloaded 22 time(s).
PD: It's a bit awkward having to define f(T) as a 1x1 matrix, while accepting guess as a scalar. I think that an interesting improvement in al_nleqsolve could be to accept scalar functions for the case of a single variable, and also return the result as a scalar, and not a 1x1 vector.
Of course, preserving the possibility that
You really want to solve a 1x1 system, recognizing it as such because f is a matrix.
Edited by user 30 March 2022 20:28:39(UTC)  | Reason: Comment about al_nleqsolve
Offline uni
#3 Posted : 30 March 2022 20:32:32(UTC)
uni
Was thanked: 1275 time(s) in 746 post(s)
First, the frame must completely cover the expressions. This needs to be checked. Secondly, it is desirable to make sure that the solver works without a block.
Here is a possible bug in the program.
Someday it will also work with block.
Edited by user 30 March 2022 20:37:50(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 30/03/2022(UTC)
#4 Posted : 31 March 2022 14:47:04(UTC)
Originally Posted by: Valentino Go to Quoted Post
I try to find the value of a temperature that when replacing it in an equation ...
If you can tabulate that curve on the image,
it might be possible to approximate with a function.
If so from possible approximation, solution will be
more general and immediate from maple/solve
thus no more need for solver bloc.
#5 Posted : 31 March 2022 19:54:37(UTC)
Here is a support example ...
The dual solver from undocumented root is exceptional
Per say: from measured Ω evaluate °C
from user ranged [min °C ... max °C] calibrated Ω XTR
Inst_IAPWS region 1 Solve Entropy Saturation.sm (38kb) downloaded 11 time(s).
Guest (2)
