Offline mkraska
#1 Posted : 05 December 2021 02:10:32(UTC)
mkraska
In interactive mode, the animation is smooth and shows the correct colors.
Federpendel - Kopie.sm (49kb) downloaded 34 time(s).
This was generated with latest SMath Solver, many sequence errors, wrong colors (dot is not red)
This was generated using build 6884, has still some glitches but much better.
Edited by user 05 December 2021 02:15:35(UTC)  | Reason: Not specified
Offline Razonar
#2 Posted : 07 December 2021 15:13:54(UTC)
Razonar
Uruguay
Hi Martin. This is a workaround. Sselect the plot and another area, for example k: range (1, n), which is above the plot. Export the animation. Then, for some reason, it asks twice for the filename. The result does not preserve the color, but at least it seems that does not lose frames.
