Offline Jonny Be Good
#1 Posted : 17 October 2021 00:56:17(UTC)
Jonny Be Good
I am trying to plot electrical resistance using Electrical Engineering Library and X-Y-Plots Plugins but it does not seem to work:
Can anyone help me plot this?
Offline overlord
#2 Posted : 17 October 2021 01:41:28(UTC)
Turkey
Delete the ohm unit in Rp.
Usually you shouldn't use units while plotting.
For information, this includes most numeric solver functions too.
Offline overlord
#3 Posted : 17 October 2021 01:46:20(UTC)
Turkey
Or if you will really need units;
Try to eliminate or add them in the input data.
It is to avoid them being used in plot.
Or to avoid conflict between unit-ed numbers and not unit-ed.
When you use Rx in your function, it can't be EEL_par with 1 ohm.
Plot try to use Rx as an number not a unit added number.
You either add unit to Rx or do opposite.
Opposite is eliminating all units of other variables.
Edited by user 17 October 2021 22:16:25(UTC)  | Reason: Not specified
#4 Posted : 17 October 2021 19:03:39(UTC)
Jonny Be Good
Thanks, this makes total sense.
Also, how is it possible to only plot (or "stem" as it is called in Matlab ) integer values?
Offline overlord
#5 Posted : 17 October 2021 20:28:23(UTC)
Turkey
Maybe I chose a wrong word to describe it, shall edit.
It will plot not only integers, numbers actually.
But plot expect them to be dimensionless.
Not just X-Y plot, built-in 2D plot also.
Edited by user 17 October 2021 22:26:33(UTC)  | Reason: Not specified
#6 Posted : 17 October 2021 22:08:04(UTC)
Jonny Be Good
Plot try to use Rx as an integer not a unit added number.
So how did you add the Ohm symbol under the plot? It won't let me add a unit there.
Offline overlord
#7 Posted : 17 October 2021 22:23:47(UTC)
Turkey
1 - Hit multiply after Rx;
2 - (Type W in place holder, place Ctrl+G) or (Click ohm from right pane);
3 - Placeholder shall appear, either double click or press tab to insert Ω as unit.
If you are not typing units after numbers, this is the way.
You can also type ' between step1 and step2.
Units can be typed or chosed with this way more quick.
This will directly open placeholder scroll menu.
Edited by user 17 October 2021 22:27:25(UTC)  | Reason: Not specified
#8 Posted : 18 October 2021 13:03:57(UTC)
Altitude is plotted integers.
Solve INVERSE Recursive NASA.sm (14kb) downloaded 3 time(s).
#9 Posted : 18 October 2021 15:30:30(UTC)
... refreshed version ½ timing.
Solve INVERSE Recursive NASA.sm (17kb) downloaded 9 time(s).
Offline overlord
#10 Posted : 18 October 2021 23:05:53(UTC)
Turkey
I don't know if there is a stem equivalent for smath plots.
But you can create your own function for that purpose.
stem.sm (9kb) downloaded 10 time(s).
#11 Posted : 19 October 2021 03:03:39(UTC)
... you can animate the stem system, have symbols too.
Here, integers are the X direction.
Eventually, easy for the Y direction as applicable.
2D Util Stem ANIM Laplace Diffusion.sm (22kb) downloaded 6 time(s).
Offline Razonar
#12 Posted : 19 October 2021 06:42:00(UTC)
Razonar
Uruguay
Hi. In addition to the overlord solution, this is another approach.
stem.sm (13kb) downloaded 21 time(s).
Edited by user 19 October 2021 06:49:16(UTC)  | Reason: Not specified
#13 Posted : 19 October 2021 16:20:17(UTC)
You can highlight some particular point(s) with glyphe(s) of you choice.
You will have to dispose their position by hand.
2D Plot Setup Glyphes.sm (29kb) downloaded 9 time(s).
Offline overlord
#14 Posted : 19 October 2021 17:19:27(UTC)
Turkey
Originally Posted by: Razonar Go to Quoted Post
...In addition to the overlord solution...
Mine was not a solution to be honest.
Just a quick and ugly way to show it is possible.
This is a good solution though.
