Offline johnnyontheweb
#1 Posted : 20 September 2021 19:35:14(UTC)
johnnyontheweb
Rank: Member
Was thanked: 3 time(s) in 1 post(s)
Hello all,
I'm new to SMath Studio, and I'm developing a plugin in VB.NET. I need to define a constant given from my code (for example, I want to type in "const=" and get an hardcoded value).
I saw that TermType can be Operand, Operator, Function or Bracket. I defined my constant as a function, and in this way I always have to type const(1) to get the value (i.e. I must use a dummy argument, which is not needed).
Do you have any hint on that? Can I defined a constant in a plugin?
thanks in advance
Online uni
#2 Posted : 20 September 2021 19:40:30(UTC)
uni
As I know it is not possible. All plugin stuff (if they are not regions) registered as functions. But I've never tried registering an operand instead of a function.
I tried. You can register the operand, but an error occurs when you try to calculate it numerically.
Edited by user 20 September 2021 20:03:57(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
#3 Posted : 20 September 2021 20:03:28(UTC)
johnnyontheweb
Rank: Member
Thans for replying
It seems I cannot also use system paths as a function arguments; I suspect there's something about encoding: I have myfunc("C:\test.txt"Wink and inside plugin code I get "C\003A\\test\002E\txt"
002E is "." in UTF8, but there's also escape chars.
Online uni
#4 Posted : 20 September 2021 20:06:49(UTC)
uni
You must use TermsConverter.DecodeText() and TermsConverter.EncodeText() for this. Examples can be found in the repository.
Edited by user 20 September 2021 20:08:38(UTC)  | Reason: Not specified
Russia ☭ forever
#5 Posted : 20 September 2021 21:50:43(UTC)
johnnyontheweb
Rank: Member
Thanks a lot. Final question: can a function return a boolean?
Online uni
#6 Posted : 20 September 2021 22:33:08(UTC)
uni
The program supports operations with numbers presented in various forms (natural, integer, rational, complex). There is no such type as boolean numbers. There are boolean operations defined on the above types. Therefore, there are numbers and operations on them, strings and operations on them, matrices and operations on them. The type of a variable is determined by its value. In symbolic form, you can return any expression allowed by the program syntax.
Therefore, if you need to return a boolean value from a plugin, then it needs to be converted to a value supported in API (see TNumber constructors). Usually, true - 1, false - 0.
Russia ☭ forever
#7 Posted : 21 September 2021 17:25:19(UTC)
johnnyontheweb
Rank: Member
Thanks, hence it would be easier to put result in an expression with a boolean operator and then return result.
I'm just wondering how to return vectors, I cannot understand from Core Documentation how to return a vector as a result. I suppose one can use some thing like: result = New Entry(New Numeric.TMatrix(... ? ))
and using 1 column only.
can you help on this?
thanks in advance
EDIT:
I did it like this - now the question is: is there a shorter way?
Code:
            Dim val() As Double = {1,2,3,4,5,6}
            Dim m(5, 0) As Numeric.TNumber
            For i = 0 To 5
                m(i, 0) = New Numeric.TNumber(val(i))
            Next
            Dim mout As New Numeric.TMatrix(m)
            result = Entry.Create(mout.ToTerms)
Edited by user 21 September 2021 17:36:04(UTC)  | Reason: Not specified
Online uni
#8 Posted : 21 September 2021 21:06:30(UTC)
uni
You can find examples in repository. Try to search in *.cs files using keyword TMatrix. And then convert to the equivalent on vb.net.
Russia ☭ forever
#9 Posted : 21 September 2021 21:49:52(UTC)
johnnyontheweb
Rank: Member
I already saw that page, thanks. Don't know if it's for vb instead of c#, but I cannot have "result = solution" since this conversion is not permitted.
Now I'm looking how to associate units (eg. N, m or MPa, etc.) for result - I didn't find any code sample for this (I thought this https://smath.info:8443/!/#public/view/head/plugins/CustomFunctions/SMathFunctions/Units/UoM.cs was ok, but I cannot understand how units are associated to result). In my case, units are not inherited from function arguments.
#10 Posted : 21 September 2021 23:30:37(UTC)
Associate unit compatible to functional operand
as exemplified ... integration is m² km² ...
Page12 Unit_Bolean.sm (14kb) downloaded 7 time(s).
Offline overlord
#11 Posted : 21 September 2021 23:37:52(UTC)
Turkey
The questions are about source code of a plugin.
Not about how to write boolean expressions in SMath.
This post is not related with topic.
If you don't get what is asked, don't answer it.
Online uni
#12 Posted : 22 September 2021 00:08:23(UTC)
uni
For example you can add units using TDouble. To determine the unit, you need to add an apostrophe in front of the text. For TryEvaluateExpression() you can use other methods (classes).
Code:
Public Class Plugin
    Implements IPluginMathNumericEvaluation
    Private _terms As TermInfo()
    Private _description As Dictionary(Of String, String) = New Dictionary(Of String, String) From {
        {"ENG", "test function."},
        {"RUS", "функция тестирования."}
    Public Function GetTermsHandled(sessionProfile As SessionProfile) As TermInfo() Implements IPluginHandleEvaluation.GetTermsHandled
        Return _terms
    End Function
    Public Sub Initialize() Implements IPlugin.Initialize
        _terms = {New TermInfo("test", TermType.[Function], _description("ENG"), FunctionSections.Unknown, True) }
    End Sub
    Public Function NumericEvaluation(value As Term, args As TNumber(), ByRef result As TNumber) As Boolean Implements IPluginMathNumericEvaluation.NumericEvaluation
        result = args(0) * ( new TDouble("'sec") )
        Return True
    End Function
    Public Sub Dispose() Implements IDisposable.Dispose
    End Sub
End Class
Russia ☭ forever
on 22/09/2021(UTC)
#13 Posted : 12 October 2021 10:38:19(UTC)
johnnyontheweb
Rank: Member
I looked in the code by I cannot find something similar to what I'm trying to do with my plugin.
A power of a length unit has to be returned as measure, but this is not working:
New TNumber(area * New TDouble("'m^2" ) )
What am I missing? It seems that "^" operand is considered in a different way when typed in SMath Studio and when coming from a plugin.
Edited by user 12 October 2021 10:39:50(UTC)  | Reason: removed smiley
#14 Posted : 13 October 2021 13:26:17(UTC)
johnnyontheweb
Rank: Member
I found an alternative, please tell if there's something shorter than this:
New TNumber(area * DirectCast(New TDouble("'m" ).Pow(New TDouble(2) ), TDouble))
