2 Pages12>
Offline Porschaka
#1 Posted : 16 September 2021 17:16:28(UTC)
Porschaka
Hello everyone!
I found some strange behaviour. Let's assume two dimensionless quantity length:=10 and temp:=12. Now I multiply length * 1m and the result is 10m. However if I multiply temp * 1degC the result is error because temp is not defined? Is it some kind of a bug?
https://ibb.co/B2203KY
Edited by user 16 September 2021 17:30:51(UTC)  | Reason: Not specified
Offline oscampo
#2 Posted : 16 September 2021 17:50:22(UTC)
oscampo
Colombia
Was thanked: 87 time(s) in 66 post(s)
Originally Posted by: Porschaka Go to Quoted Post
Hello everyone!
I checked and it's really strange Shok
#3 Posted : 16 September 2021 18:09:36(UTC)
Match units user style
Offline oscampo
#4 Posted : 16 September 2021 18:14:59(UTC)
oscampo
Colombia
Sorry, but that is not the problem we are talking about...
thanks 1 user thanked oscampo for this useful post.
on 17/09/2021(UTC)
#5 Posted : 16 September 2021 18:25:12(UTC)
Offline oscampo
#6 Posted : 16 September 2021 18:34:28(UTC)
oscampo
Colombia
why you type an additional "'" between temp and °C ?
It is enough to type: temp*'°C=
#7 Posted : 16 September 2021 18:48:50(UTC)
To make the unit silent but responding.
Had been used/demonstrated ad nauseum.
Most useful in program, still conveying meaning.
Offline oscampo
#8 Posted : 16 September 2021 19:10:58(UTC)
oscampo
Colombia
It's a trickier way to make things work (why use this "trick" with Celsius Degrees but not with Meters?)
A little exaggerated affirmation...and not documented on common help documents (Interactive Guide, Handbooks, nor wiki)
Offline Porschaka
#9 Posted : 16 September 2021 20:39:43(UTC)
Porschaka
It looks like a bug to me. Is there a chance that it will be fixed any time soon? What do you think? Will use "'" between temp and °C for now...
#10 Posted : 16 September 2021 20:55:32(UTC)
The two you mention are little fraction of all Forum projects.
Silent unit is not documented as wellroot that works superb.
However, silent is coded ... otherwise would cry to murder !
I like you Oscar, take care ... Jean.
Offline oscampo
#11 Posted : 16 September 2021 21:21:08(UTC)
oscampo
Colombia
Yep! I agree. I just reported the issue in bug section of the forum.
Regards!
on 16/09/2021(UTC)
Offline oscampo
#12 Posted : 16 September 2021 21:56:33(UTC)
oscampo
Colombia
The ‘silent unit’ is only mentioned by you only in 5 topics (this is only 5 or 6 posts) in the entire forum, and nobody discussed about it, so, here, in this forum, there is not enough documentation about it either there is not information about it on SMath Interctive Guide, SMath Handbooks, nor SMath Wiki
The ‘silent unit’ is not the question in this topic.
The issue originally mentioned by Porschaka looks like a bug, so it was reported in the corresponding section.
Offline wb.c
#13 Posted : 16 September 2021 22:12:31(UTC)
wb.c
Was thanked: 22 time(s) in 19 post(s)
Very strange, seems to be °C, °F, and °Re.
Interestedly enough, these are the units labeled in the units.xml file as nonlinear. I don't know what any of this means, but I'm sure it has something to do with the built in functions that get us these three units.
thanks 1 user thanked wb.c for this useful post.
on 16/09/2021(UTC)
Offline wb.c
#14 Posted : 16 September 2021 22:33:34(UTC)
wb.c
Keep in mind that if you define a new dummy unit for °C by adding a "'" to the front, you don't solve your problem.
The conversion for these 3 units is not linear, meaning you can't just multiply by a factor to get the conversion.
If you are only planning on working with your own isolated units without taking advantage of the built in units, then go right ahead and define a custom version of the unit.
This issue needs to be solved in the programing or with a custom function that does the conversion for you the right way and can handle the nonlinear units.
on 16/09/2021(UTC)
Offline CBG
#15 Posted : 17 September 2021 00:07:39(UTC)
CBG
Hello
I think the following can be done
Carlos
thanks 2 users thanked CBG for this useful post.
on 17/09/2021(UTC),  on 17/09/2021(UTC)
#16 Posted : 17 September 2021 02:05:14(UTC)
OK Oscar, explain to yourself what the unit should be:
10m*1°C ... Ask SI Community.
Eager to discover ... Jean.
You assign unit to undefined,
do it otherwise: put °C in result.
Offline oscampo
#17 Posted : 17 September 2021 02:11:41(UTC)
oscampo
Colombia
Jean...
That's not the point of discussion. Please check the original post.
on 17/09/2021(UTC)
Offline oscampo
#18 Posted : 17 September 2021 03:34:44(UTC)
oscampo
Colombia
Jean, please don't spam the topic with irrelevant information...
on 17/09/2021(UTC)
#19 Posted : 17 September 2021 04:15:27(UTC)
You are right: Carlos has doctored your red image.
Reynolds is one more doctored for Engineers
... for Smath Community as profitable.
Offline overlord
#20 Posted : 17 September 2021 04:28:32(UTC)
Turkey
thanks 3 users thanked overlord for this useful post.
on 17/09/2021(UTC),  on 17/09/2021(UTC),  on 17/09/2021(UTC)
Guest (2)
2 Pages12>
