Offline Necronomicron
#1 Posted : 15 September 2021 16:22:58(UTC)
Necronomicron
Belarus
Hello!
I have an equation (sphere and cubic Bézier curve intersection points): B(t) ⋅ B(t) = r², where dot means vector dot product.
B(t) is a cubic Bézier curve:
B(t) = (1 − t)³ ⋅ P0 + 3t ⋅ (1 − t)² ⋅ P1 + 3t² ⋅ (1 − t) ⋅ P2 + t³ ⋅ P3, 0 ≤ t ≤ 1
P0, P1, P2, P3 are some known points, к is some known value too.
Is it possible to solve this using SMath while keeping constants as letters?
Edited by user 15 September 2021 17:51:55(UTC)  | Reason: Not specified
#2 Posted : 15 September 2021 17:08:25(UTC)
Please attach your Smath document.
Bézier/Hermite ... lot in Smath.
#3 Posted : 15 September 2021 17:49:13(UTC)
Necronomicron
Belarus
https://ru.smath.com/cloud/sheet/ao2a4mLPSz
Well, not much in there, I don't know how to write the equation in it. I am new to SMath, and used only MathCAD a few times, like, 13-14 years ago...
Offline oscampo
#4 Posted : 15 September 2021 18:19:37(UTC)
oscampo
Colombia
Was thanked: 86 time(s) in 66 post(s)
"Error. There is no Worksheet found."
Please upload your sm file to any cloud service a share the link
Oscar
#5 Posted : 15 September 2021 18:24:03(UTC)
Necronomicron
Belarus
Sphere and cubic Bezier curve intersection points.sm (11kb) downloaded 10 time(s).
Oscar
Edited by user 15 September 2021 18:26:53(UTC)  | Reason: Not specified
Offline oscampo
#6 Posted : 15 September 2021 19:00:26(UTC)
oscampo
Colombia
You must use Symbolic evaluation to solve your equation, additionally, you can use some plugin for this task (in my case I used the Maxima plugin).
Please see attached file:
Sphere and Cubic.sm (216kb) downloaded 19 time(s).
Offline overlord
#7 Posted : 15 September 2021 20:21:28(UTC)
Turkey
All those kind of symbolic solvings require either Maxima or Maple plugin as far as I know.
Every other smath solvers [solve(), roots(), FindRoot(), al_nleqsolve(), etc] are numerical solvers.
Could someone correct this statement if it is not true?
Edited by user 15 September 2021 20:42:03(UTC)  | Reason: Not specified
Offline oscampo
#8 Posted : 15 September 2021 20:33:35(UTC)
oscampo
Colombia
Every other smath solvers [solve(), Roots(), al_nleqsolve(), etc] are numerical solvers.
yes, that's correct, you can check the description of solve(), roots(), al_nleqsolve(), etc on the Interactive SMath Handbook
Offline Razonar
#9 Posted : 16 September 2021 02:57:18(UTC)
Razonar
Uruguay
Hi. In the attached how to solve the problem numerically. Notice that B(t) must to be defined using vectorize, because SMath don't expand the scalar by vector products.
Sphere and Cubic.sm (9kb) downloaded 6 time(s).
on 16/09/2021(UTC)
#10 Posted : 16 September 2021 12:43:49(UTC)
Necronomicron
Belarus
There is missing «²» after second parentheses in your file. And I downloaded SMath and Maxima, but when I open your file, I get an error: «Cannot find maxima.bat».
Sphere and cubic Bezier curve intersection points.sm (4kb) downloaded 5 time(s).
Edited by user 16 September 2021 12:50:55(UTC)  | Reason: Not specified
Offline oscampo
#11 Posted : 16 September 2021 13:33:52(UTC)
oscampo
Colombia
Please refer to Maxima plugin instructions, you can find here
#12 Posted : 16 September 2021 14:18:04(UTC)
Necronomicron
Belarus
OK, I've fixed the error, but now it says: «r is undefined». Sorry, it's really hard to understand what to do and I can't find any proper docs about it...
Sphere and cubic Bezier curve intersection points.sm (5kb) downloaded 3 time(s).
#13 Posted : 16 September 2021 14:43:30(UTC)
Necronomicron
Belarus
I really don't get what's wrong now...
Sphere and cubic Bezier curve intersection points.sm (13kb) downloaded 13 time(s).
Offline oscampo
#14 Posted : 16 September 2021 15:40:26(UTC)
oscampo
Colombia
There is a missing "*"
#15 Posted : 16 September 2021 17:07:40(UTC)
Necronomicron
Belarus
Thank you! But what should I do with «r is undefined»? 🤔
Offline oscampo
#16 Posted : 16 September 2021 17:12:25(UTC)
oscampo
Colombia
Are you sure you are using the option "Symbolic Optimization"?
You must right-click over your equation, then choose Optimization-Symbolic
#17 Posted : 16 September 2021 17:40:06(UTC)
Necronomicron
Belarus
Thank you very much! It worked! However, the roots are so long... Not sure I can use them... Thanks anyway! 😊
Offline Razonar
#18 Posted : 16 September 2021 20:52:16(UTC)
Razonar
Uruguay
Hi. Notice that P0, ..., P3 are vectors with 3 components, not scalars. You can't get the distance with B(t).B(t) using P's as scalars.
#19 Posted : 17 September 2021 02:16:44(UTC)
Didn't see the sphere ?
Bézier is a 2 D plot
I don't understand your project, will leave.
You can project Bézier as surface plot on the sphere,
at this point, all 'N' are roots.
Enjoy/ignore ... Jean.
Page6 Bezier.sm (31kb) downloaded 5 time(s).
Offline overlord
#20 Posted : 17 September 2021 03:20:45(UTC)
Turkey
Not related with topic. Nice example to Bezier however no relation with question.
Seeing Bezier in question doesn't mean you can search your files and post your first match Bezier example.
on 17/09/2021(UTC)
