SMath Studio Forum
Questions
How can I evaluate the variables in the loop
Joined: 07/12/2018(UTC) Posts: 44 Was thanked: 1 time(s) in 1 post(s)
Dear Smath-experts, How can I evaluate the variables in the loop in SMATH? I want to see how the variables are changing in the loop like in python. Is what debug is for, but how does it work? Best regards, Andrey
You can either use the function trace() to show some specific variables (data will be shown in the "output" window on the fly without stopping evaluations) or use the debugger. This is more in "Visual Studio IDE style" and shows you the whole context in a specific point (the breakpoint); this means that the execution is paused when those points are evaluated. To add/remove a breakpoint you can use the context menu (mouse right-click) |
Originally Posted by: andrbig77 I want to see how the variables are changing in the loop You can see it outside the loop, same more vivid. Cheers ... Jean. 0Anim Landing.sm (57kb) downloaded 13 time(s).
Joined: 10/12/2009(UTC) Posts: 249 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Best regards, Andrey Hi Andrey, you can use trace() for check how variables are changing in the loop: Regards, Oscar
... for convenience make it algo style collapsed in utilities. Thus, you will have it from in-situ command line. Cheers ... Jean. Utilities Discrete CUMULATIVE algo.sm (5kb) downloaded 4 time(s).
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
trace() or breakpoints are usually de-facto way to go. Alternatively you can store variables to a matrix. Regards Edited by user 11 September 2021 16:39:18(UTC)
| Reason: Not specified
SMath Studio Forum
Questions
