Offline sleschke
#1 Posted : 06 February 2009 23:30:50(UTC)
sleschke
Rank: Member
I was a bit suprised about the way the percentage function works.
It would look so much nicer if the percentage sign '%' would be used as postfix operator
(like the factorial operator "!"Wink.
I know that this will not always be an adequate replacement in a formula,
but for defining constants it would be great.
Maybe when you start implementing physical units you can treat percentage as a unit.
Offline mkraska
#2 Posted : 27 June 2012 12:37:57(UTC)
mkraska
I support this proposal.
What can be done: (unfortunately 'Prozent:0.01 does not work)
'Prozent:0.01
2*'Prozent=0.02@#
{2*'mm}/'m=0.2@'Prozent
Using the % sign would be much more intuitive for the user. It is easy to write this on paper, the letter is easy to type, thus why not use it?
I have in mind the usage for mechanical engineering applications, e.g. for strain. Here even the per-thousand symbol would be welcome.
I tried to extend the units definitions (Units.xml under Entries)
<unit value="0.01" description="581" dimension="All">
<name lang="eng" text="'%" />
</unit>
This failed, just as the attempt to define a unit '% interactively fails. First obstacle is the binding of the %-key to the plus/minus-operator. Second obstacle is that when editing a unit name string the GUI doesn't even accept %-characters from the clipboard.
Best regards, Martin Kraska
on 28/06/2012(UTC)
