Offline Infinity
#1 Posted : 19 June 2012 20:38:11(UTC)
Infinity
Rank: Member
Was thanked: 3 time(s) in 2 post(s)
I found a bug when accessing not assigned positions within a matrix.
In the following example I assigned on variable 'a' a matrix with two rows and one column.
Now when I access not assigned rows or columns I also get values back.
See my example below:
SMath Version 0.95
Example Matrices Bug
Best Regards,
Infinity
Offline omorr
#2 Posted : 19 June 2012 21:27:11(UTC)
omorr
Serbia
Hello Infinity,
I suppose it has something with internal representation of matrix with mat() function:
marix size
Hmm...I am not sure if it could be accepted as a feature or a bug Unsure
I prefer this to be regarded as a bug.
Offline Andrey Ivashov
#3 Posted : 21 June 2012 01:12:40(UTC)
Yep, it's a bug. Will fix.
Thank you and regards.
on 21/06/2012(UTC)
Offline Stuart Bruff
#4 Posted : 21 June 2012 02:06:29(UTC)
Stuart Bruff
United Kingdom
However, ... what would be nice is if, in Matlab style, a single index could point into a 2D matrix
(ie, the first index in this case would not be needed) ... except I'd prefer it if the indexing took place in column order rather than row order. Smile
Stuart
M:mat(1,4,7,2,5,8,3,6,9,3,3)
v:line(for(k,range(1,rows(M)*cols(M)),el(v,k):el(M,1,k)),v,2,1)
transpose(v)=mat(1,4,7,2,5,8,3,6,9,1,9)
... sorry, that first MATH line is supposed to be a 3x3 matrix and the second MATH line is supposed to be showing a program: v:line(for(k,range(1,rows(M)*cols(M)),el(v,k):el(M,1,k)),v,2,1)
Edited by user 21 June 2012 02:19:49(UTC)  | Reason: doesn't display what I intended
Offline omorr
#5 Posted : 21 June 2012 09:44:30(UTC)
omorr
Serbia
It crossed my mind that stack(1) and augment(1) might be made to be used with a single argument - matrix with more than one row and one column - in that way that stack(M) will make a column vector by placing matrix columns one below the other and augment() will make a row vector by placing matrix rows next to each other.
#6 Posted : 21 June 2012 10:21:15(UTC)
Was thanked: 1338 time(s) in 878 post(s)
Hi Good
an alternative way to transform a matrix in a vector, whitout loops (could be useful for large matrices, I think)
mat2vector snippet
here is the file in the image: mat2vector.zip
regards,
w3b5urf3r
on 21/06/2012(UTC)
#7 Posted : 24 June 2012 19:19:24(UTC)
Fixed, with improvement:
Regards.
on 24/06/2012(UTC)
Offline mkraska
#8 Posted : 24 June 2012 23:09:00(UTC)
mkraska
Was thanked: 1127 time(s) in 723 post(s)
I guess that indexing order (row or column) is a matter of taste. As I understand Andrey's post, the default order is going to be changed from row order in 0.95 to column order.
This is what 0.95 does:
for(i,range(1,rows(M)*cols(M)),el(v,i):el(M,1,i))
Accessing the transpose should provide column ordering:
for(i,range(1,rows(M)*cols(M)),el(v,i):el(transpose(M),1,i))
However, the result is a complaint, that the requested element does not exist.
If the matrix is transposed in advance, the trick works:
M:transpose(M)
transpose(v)=mat(1,2,3,4,5,6,7,8,9,1,9)
Also, use of eval works.
for(i,range(1,rows(M)*cols(M)),el(v,i):el(eval(transpose(M)),1,i))
I don't have an idea, how to explain these differences.
Slightly off topic: IMHO linear indexing in general does not contribute to the readability of algorithms (the reader must make assumptions on row or column ordering). In contrast to this I would highly welcome another matlab feature: impicit iteration over vector valued indices.
They would be a highly welcome equivalent to Mathcad range variables and are consistent to the usual math notation.
Best regards, Martin Kraska
Edited by user 24 June 2012 23:11:44(UTC)  | Reason: Not specified
on 25/06/2012(UTC)
#9 Posted : 25 June 2012 00:44:54(UTC)
Stuart Bruff
United Kingdom
Yes.
That is my understanding too.
Quote:
...IMHO linear indexing in general does not contribute to the readability of algorithms (the reader must make assumptions on row or column ordering).
Although the reader may not be able to implicitly determine the element order for a single index into an array, this is, I believe, one of those cases where the application's rules determine the interpretation, as in Matlab. The ability to use a single index is potentially useful for multi-dimensional array (MDA) indexing (where the number of dimensions can be arbitrarily large).
The whole topic of array handling is probably worthy of separate discussion, covering, for example, indexing of multi-dimensional arrays, nested arrays and tensors.
... if such things as MDAs and tensors are for the distant future, then I propose that the provision of IsArray, IsScalar and IsFunction functions would be immediately useful for manipulating nested arrays and a more direct indexing for nested arrays would be beneficial, eg nested indexing on left hand side of an assignment or el having as many arguments as are necessary to index an arbitrarily deep nested array.
Stuart
#10 Posted : 25 June 2012 08:48:45(UTC)
Stuart Bruff
United Kingdom
Fixed, with improvement:.
I just played with the update and I see that a single-index returns the results in row order.
A note from one of the Wiki tutorials:
"It is important to indicate that even though you can form row vectors, many of the matrix and vector functions defined in SMath Studio apply only to column vectors. Thus, column vectors are considered true vectors for the purpose of matrix operations in SMath"
If one creates a vector by use of a single indexing then the result is a column vector. So, for a 3x3 array my expectation would be that, dropping the second (column) index would be equivalent to retaining the first (row) index and that M<sub>2</sub> would return M<sub>2,1</sub> rather than M<sub>1,2</sub>. There is a lot of Matlab and Mathcad code out there that could be mapped to SMath and it would seem to make sense to use an indexing order that requires less modification to get it to run under SMath.
Just a thought, before the feature gets into regular use ...
Stuart
Offline mkraska
#11 Posted : 25 June 2012 09:23:55(UTC)
mkraska
here are my observations with build 4559. Highlighting is done for what I think is inconsistent.
  • linear indexing using just index values beyond the limits is now suppressed ("Requested matrix element does not exist" ):
    el(mat(1,2,3,4,5,6,7,8,9,3,3),1,5)=#@#
  • linear indexing using a single index works as announced, uses row ordering:
    el(mat(1,2,3,4,5,6,7,8,9,3,3),4)=4@#
  • linear indexing beyond the number of elements is now suppressed. The error message "Argument doesn't match to expected kind" is wrong. Should be "Requested matrix element does not exist"
    el(mat(1,2,3,4,5,6,7,8,9,3,3),10)=#@#
  • linear indexing does not work with matrix-valued functions (like transpose, inverse, etc), unless they are "eval"uated. Message "Argument doesn't match to expected kind"
    el(transpose(mat(1,2,3,4,5,6,7,8,9,3,3)),7)=#@#
  • column ordering is achieved by the following slightly cumbersome expression
    el(eval(transpose(mat(1,2,3,4,5,6,7,8,9,3,3))),7)=3@#
  • Nested el work (but do not try to transpose any of the sub-matrices)
    el(el(el(mat(1,2,3,4,mat(1,2,3,4,5,6,7,8,mat(1,2,3,4,5,6,7,8,9,3,3),3,3),6,7,8,9,3,3),5),3,3),7)=7@#
I would expect el(1), i.e. linear indexing, to work on any matrix valued function. Currently, it seems to work for expressions of type mat() and el(). el(2) has no problems with matrix valued functions:
el(el(el(mat(1,2,3,4,mat(1,2,3,4,5,6,7,8,transpose(mat(1,2,3,4,5,6,7,8,9,3,3)),3,3),6,7,8,9,3,3),5),3,3),1,2)=4@#
Guest (2)
