Hello, I am using smath version 0.99 build 7822 and coolprop plugin 6.1.7713.14622 and I have the error in the image, you can view it at this address "https://i.postimg.cc/pVKhFJDK/Immagine.png" how can I solve it? Thanks in advance.
Originally Posted by: gabrago I am using smath version 0.99 build 7822 and coolprop plugin 6.1.7713.14622 and I have the error in the image, That stuff is Viacheslav baby. WASP from Katmar is not freeware, but works 5 min per session. For else fluids, I use standard data table. Doing so, my projects are traceable thus pass QA [Quality Assurance].
Sorry but you did not help me very much, thanks anyway for your time.
Originally Posted by: gabrago Sorry but you did not help me very much, thanks anyway for your time. CoolProp is supposed to work in Excel, try as offered. It is such a huge system, unlikely compatible from Smath version to version. 2015, an Smath guru [Anonymous by respect] offered an immense work sheet. only one did work. The remaining is all red ... [from recollection SS 5346 ?]
Originally Posted by: gabrago Sorry but you did not help me very much, thanks anyway for your time. From design or else wrongdoing the built-in unit system should be evaporated to avoid idiotic results. I Consulted for years with my Ti-58/59 w/o units. Inst_Viscosity Water.sm (44kb) downloaded 3 time(s).
Originally Posted by: Jean Giraud That stuff is Viacheslav baby. Authors: Davide Carpi and Mike Kaganski. Plugin updated, but now the error is different: Edited by user 04 July 2021 12:28:49(UTC)
Hi Viacheslav. After a clean SMath installation, coolprop don't appear as defined function. My windows is 32 bit, do you have where to check that? Thanks in advance. Alvaro.
It's true, functions are not loaded. I have tested the plugin with local build. Something goes wrong when building on the server. I asked Andrey about it. Edited by user 05 July 2021 07:44:46(UTC)
I thought the "not loading" functions are an issue for linux. And I thought plugin is written maybe only for windows. So error was general then.
