Offline overlord
#1 Posted : 23 May 2021 00:03:25(UTC)
Turkey
importData() function doesn't respect the string input for any of delimiters.
Function only accepts if delimiters are 0 in SMath, string inputs are giving error to wrong file format.
Column separator should be space, decimal separator should be dot, argument separator should be semicolon in file.
All delimiter separators couldn't be read even if they are specified as strings to default values in function.
Additionally, I get that strings should be in quotes while importing to SMath but this is not productive.
If there was an option for f.sym to read non-quoted text as string it would be very good.
This option could be set as integer 2 for f.sym and eliminates to manually add quotes for strings in file.
I encountered this on linux.
In order to check if I am not wrong doing also checked on windows.
Function acts same on Both operating systems.
PS: I had to rename filename csv to txt to upload here.
Usually filetype for these files is csv.
Worksheet1.sm (3kb) downloaded 9 time(s).
spreadsheet.txt (1kb) downloaded 10 time(s).
Edited by user 23 May 2021 00:05:50(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#2 Posted : 23 May 2021 00:43:31(UTC)
Thank you. Fixed.
on 23/05/2021(UTC)
Offline overlord
#3 Posted : 17 June 2021 20:58:52(UTC)
Turkey
Originally Posted by: Andrey Ivashov Go to Quoted Post
Thank you. Fixed.
I noticed another bug.
If you enter first row and leave last row as 0, file is read properly.
Same action is not working with column delimiters.
It expects a number, don't accept zero as last column delimiter.
Function throws a bug.
Offline overlord
#4 Posted : 24 February 2024 06:53:15(UTC)
Turkey
This has not been fixed as it seems.
Similar Topics
how to use importData() (Bugs & Problems)
by kompre 26/01/2022 19:01:16(UTC)
Anable to import data using importData() function (Bugs & Problems)
by Oleg@smath.com 07/11/2020 18:58:02(UTC)
