Hi, I have a problem using length() commang. If used on matrix, it works well, but using the length() command on scalar value (which is, I think, matrix of size 1 by 1), it doesn't work well. File with this problem: length_problem.sm. Edited by moderator 29 May 2012 01:47:38(UTC)
| Reason: Not specified
You get the last math region lx_1=length(-1). If yoo would use numerical equal to, there would be an error issued. And, no - scalar is not a matrix of size 1 by 1.
Regards, Rdaovan |
Hello, thank you for your reply. Is trere any other way (instead of using "length()" command) how to find out the number of solutions of the equation? Thank you for amazing SMath, kind regards Jan Skapa Originally Posted by: omorr Hello,
Regards, Rdaovan
Hello, Originally Posted by: ska109 Is trere any other way (instead of using "length()" command) how to find out the number of solutions of the equation? Could you be more specific, please? Regards, Radovan |
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1338 time(s) in 878 post(s)
Hi, I don't see your file therefore I'm not sure, but I think that this snippet can help you: varManager.zipEDIT(1): now i can see your file use it in this way: x_1:ToArray(x_1)EDIT(2): instead of x_1:ToArray(x_1) you can use x_1:stack(x_1) ( x_1 can be an array, a scalar or a text) then you can use: length(x_1)regards, w3b5urf3r Edited by user 18 June 2012 12:23:35(UTC)
