Hi all! I have problem when I try to install the following plugs: Excel Files plugins MaximaPlugin Script Region muMath Files plugin I get this message: "Plug-in(s) installation failed" All plugins are working fine except these four that I mentioned. I am under Windows 10 pro. I use maxima-5.45.0 and Office 365. Any help would be welcome. Best regards Edited by user 10 June 2021 14:36:08(UTC)
| Reason: Not specified
Confirmed for Maximaplugin with a new portable version 7822. However, automatic upgrade of an installed version with Maximaplugin to 7822 works. Maximaplugin remains functional. Didn't test with Maxima 5.45 though, but the problem is before you even can specify the path to Maxima. Edited by user 10 June 2021 22:17:20(UTC)
Maxima plug-in corrected. Please update it using Extensions Manager.
Thank you Andrei for the updates. Now Maxima, Excel Files and muMath Files plugins work fine. Only Script Region plugin don't work.
Script region rebuilt and can be installed to the latest SMath Studio version again. Thanks.
