hi can anybody please explain why the following does not work, and how I need to change it............. many thanks
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
Originally Posted by: 009jim hi can anybody please explain why the following does not work, and how I need to change it............. many thanks No problem here. You have misspelled the function. The equality for 3*4 or 4*k is next to matrix element. It has to be next to matrix, whole of it. Regards COL_FOR.sm (5kb) downloaded 13 time(s).Edited by user 25 May 2021 01:22:14(UTC)
| Reason: Not specified
Thank you "overlord"..............what a basic error, I feel stupid, must need new spectacles. hehe.
Originally Posted by: 009jim what a basic error, I feel stupid No need to be. Everybody make mistake, especially if it is simple. Feel free to ask questions. Someone shall reply, be sure of it. Regards
Originally Posted by: 009jim can anybody please explain why the following does not work Your coding is wrong for your application, but correct for other application(s) ... StripX(data).
Folks, I have another query please and am grateful for help. As per diagram below, how do I move several lines down and create space for another equation inside my "for" loop.
Originally Posted by: 009jim Folks, I have another query please and am grateful for help.
Use your arguments separator for this. This works also for vectors but not for matrices. Regards
Originally Posted by: 009jim how do I move several lines down and create space
Originally Posted by: overlord Use your arguments separator for this. thank you, but can you please clarify what exactly is the "arguments separator" ?
Originally Posted by: 009jim Originally Posted by: overlord Use your arguments separator for this. thank you, but can you please clarify what exactly is the "arguments separator" ? It depends on your setting. Its setting is under Tools > Options. I use semicolon, default is comma I guess.
Originally Posted by: 009jim how do I move several lines/cols down/right and create space
Joined: 02/04/2018(UTC) Posts: 136 Was thanked: 22 time(s) in 19 post(s)
This is like Schrodinger's answer, both right and wrong at the same time, lol.
Originally Posted by: wb.c This is like Schrodinger's answer, both right and wrong at the same time, lol. I greatly admire that you have recognized the long functional romance was Shrodinger lol ! Otherwise coded from Mathcad ODEsolve . Maths Schrodinger.sm (68kb) downloaded 8 time(s).
