Offline andrbig77
#1 Posted : 05 May 2021 13:57:12(UTC)
andrbig77
Dear SSMath Developer,
I think the SSMath version ( "0.99.7792" ) has a bug.
If one couples an object from the math. formula (with help of CTRL+C), then CTRL+V, then appears instead of the variable at the page a graphic
Best regards,
Andrey
#2 Posted : 05 May 2021 14:48:10(UTC)
This is because the plugin implements
Code:
public string[] SupportedClipboardFormats => new[] { DataFormats.UnicodeText };
Hence when a plain text is passed the plugin handle the action.
Guess would be needed a "paste as" when multiple plugins are available for such task, with the built-in as default (if any).
on 06/05/2021(UTC)
Offline andrbig77
#3 Posted : 07 May 2021 15:46:10(UTC)
andrbig77
Code:
Hello Davide,
thank you for your answer.
Now I have the dilemma, which plugin is responsible for this effect...
I have to turn on and off each plugin step by step to determine it.
Best regards,
Andrey
#4 Posted : 07 May 2021 19:37:26(UTC)
Is the plugin that is shown when you paste the data
So in this case is XYPlotRegion probably
Edited by user 07 May 2021 23:45:41(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#5 Posted : 10 May 2021 23:28:30(UTC)
I've corrected plug-ins to disable handling of text from clipboard by default (as I see it was activated by mistake because of using the same code templates).
So issue is gone. One just need to update installed plug-ins. Note: the latest SMath Studio beta must be used.
Offline andrbig77
#6 Posted : 11 May 2021 13:52:10(UTC)
andrbig77
Hello Andrey and Davide,
thank you for the help and the fixing of this nice tool.
Best regards,
Andrey
Guest (2)
