Joined: 29/04/2021(UTC) Posts: 1 Location: staffs Was thanked: 1 time(s) in 1 post(s)
Hi SMath throws an exception when I plot a matric containing a large number (such as 3.1*10^8) - any ideas what I'm doing wrong? Many thanks John
1 user thanked johnofleek for this useful post.
Originally Posted by: johnofleek SMath throws an exception when I plot a matric containing a large number (such as 3.1*10^8) - any ideas what I'm doing wrong?
The quick plot plots on canvas pixels The first abscissa @ 1, 2nd @ 2 The third one @ roughly 100 km at right. At that distance, they don't shake hands !
Many thanks
John Below there you can find the file. You didn't do anything wrong. I guess this is a bug. Plot can show the results, but give a bug and force crash if you don't do it right way. If you insert the 2d plot, add the variable and try to scroll it right after smath crashes. Maybe during scrolling plot can't do the refreshing, hit a wall and quit I don't know. Well, right way is a work around actually since this is a bug. NOT the way "you have to do this like this always". I did altered 3x10^8 to 3x10^4 then scrolled to see the graphic better. Then altered it again to 3x10^5 and scrolled again. Gradually revising number and scrolling made it to 3x10^8. Plot is changing correctly after this phase. Tried with couple of them and not crashed. Regards ploterror.sm (10kb) downloaded 8 time(s).
Bug confirmed, it is about coordinates in mouse events. bug.sm (3kb) downloaded 9 time(s).Code:************** Text of Exception **************
System.OverflowException: Value too large or too small for an Int32.
in System.Convert.ToInt32(Double value)
in ..(Int32 , Int32 )
in SMath.Controls.Renderer.Refresh()
in SMath.Controls.Renderer.OnMouseMove(MouseEventOptions e)
in SMath.Controls.RegionHolder`1.OnMouseMove(MouseEventOptions e)
in SMath.Controls.Worksheet.MouseMove(MouseEventOptions e)
in SMath.Controls.InteractiveWorksheet.MouseMove(Single x, Single y, Int32 count)
in SMath.UI.Desktop.DesktopWorksheet.(MouseEventArgs )
in System.Windows.Forms.Control.WmMouseMove(Message& m)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Originally Posted by: johnofleek SMath throws an exception when I plot a matrix containing a large number (such as 3.1*10^8) - any ideas what I'm doing wrong ? I notice in my early SS 5346 [2015] Simply, before you plot, set either X or Y close to max of either X/Y as applicable That clears the mouse incompatibility from initial default plot. You may encounter that in plotting ordinary f(x). The X_Y plot will surely crash Smath.
Thank you, reproduced. Will fix.
Originally Posted by: Andrey Ivashov Thank you, reproduced. Will fix. This is not fixed in 2D plot. It is fixed in X-Y Plot. Just a reminder. Regards
