Offline scottg
#1 Posted : 27 February 2012 19:09:48(UTC)
scottg
I found a minor problem with trigonometric functions. The following problem occurs only for a value of 30 degrees, as you can see the value of sin evaluates differently depending on the construction of the math. And only when I am modifying the value of phi in expression shown.
It would not be a problem if a value of phi = 30 was not common in geotechnical engineering.
φ:30deg
γ:1.3
δ:atan(tan(φ)/γ)
δ=23.9468@'deg
β:sin(δ)
β=1.2177
sin(δ)=0.4059
Any thoughts?
Offline omorr
#2 Posted : 27 February 2012 22:13:33(UTC)
omorr
Serbia
The solution is to apply Optimization|Numeric or None on the region:
δ←atan(tan(φ)/γ)
This is a common advice to do first when you need just the numerical values.
BTW, the degrees does not work properly in v0.92
Offline Andrey Ivashov
#3 Posted : 27 February 2012 22:18:41(UTC)
It doesn't wort in one case only - when you try to evaluate it numerically in a single line like:
P.S.: Will try to release new SMath Studio version as soon as possible.
Regards.
on 27/02/2012(UTC)
Offline scottg
#4 Posted : 28 February 2012 12:18:42(UTC)
scottg
Thanks for the help
Offline PompelmoTell
#5 Posted : 05 March 2012 12:47:22(UTC)
PompelmoTell
Also in v.093 remains the problem reported by Scottg. The solution indicated by Radovan, it works properly.
Sergio
on 05/03/2012(UTC)
#6 Posted : 30 May 2012 23:04:55(UTC)
Fixed in SMath Studio 0.94.
Regards.
on 30/05/2012(UTC),  on 30/05/2012(UTC)
