#1 Posted : 28 May 2012 19:32:39(UTC)
another little bug, I think...
bug eval() vs loops
note that the results are right (also for bigger scripts inside the loop)
here is the file in the example: bugs%2feval_for_0.94_debug.sm.zip
regards,
w3b5urf3r
Offline TheWizEd
#2 Posted : 29 May 2012 03:26:29(UTC)
TheWizEd
Was thanked: 19 time(s) in 13 post(s)
w3b,
I can't explain the error but I don't understand the eval()s. eval() is the same as "=".
Ed
#3 Posted : 29 May 2012 07:15:51(UTC)
Hi WizEd Good
eval() speeds up the calculations (<10 seconds vs 20,30 seconds or minutes, if i remove all eval()s from entire script... i don't know how, but works Biggrin )
regards,
w3b5urf3r
Edited by user 29 May 2012 10:18:45(UTC)  | Reason: Not specified
Offline mkraska
#4 Posted : 29 May 2012 20:14:28(UTC)
mkraska
I am not sure if that is a bug or a feature. My theory on eval is that it enforces immediate evaluation when used on the right hand side of assignment operations. In your example, however, there is no assignment of the eval result. eval just tries to evaluate the statements inside the line operation and as a last step tries to determine the return value of the line operation (which is normally the value of the last line).
The last line, in your case, is a for statement, which is just a flow control statement and seems not to have a return value on it's own. Therefore, the last line has no return value and eval complains.
I may be totally wrong, still just providing any other line at the end resolves the error message.
eval(for)
Best regards, Martin Kraska
on 29/05/2012(UTC)
#5 Posted : 30 May 2012 01:11:53(UTC)
hi mkraska,
Thank you! I agree with your analysis Good
probably the use of eval() in the left side is not conventional, however the error message is quite obscure, I think Wonder ...
for the visual error I had done differently, moving the eval() inside the for loop... in addition to eliminating the red border seems to be slightly faster, although I do not understand why (hundreds of eval() instead of one...)
best regards,
w3b5urf3r
Edited by user 30 May 2012 10:52:55(UTC)  | Reason: Not specified
Guest (2)
