Hello, I found 2 strange behaviors / bugs with matrix handling. On the left side of the picture you see some operations with extracting and overwriting cells. All works fine except to the last few lines. On the right side I get an error message but the code still works fine. I don't know what is wrong with this code (maybe the bug is the user here ;-). It seems that this behavior is all the same in the 0.9x series of SMATH, in 0,89 the left side works fine but not the right side. I use SMATH 0,94 build 4523 on linux. Can anyone check this and confirm? Here is the SMATH file: matrix-bug.sm.zipEdited by moderator 29 May 2012 01:48:15(UTC)
| Reason: Not specified
Hello, I think there is some kind of misunderstanding here. There is a mistake to define variables in this way and both definitions of variables are incorrect (result and result2). You can see that by hovering the mouse over them. You should define variables like this: line(k:0,for(i,range(1,length(X)),line(k:k+1,el(result,k):el(X,i)*el(Y,i),2,1)),result,3,1)and for(i,range(1,length(X)),el(result2,i):el(X,i)+el(Y,i))Additional result:= and result2:= in front of these constructions are making a mess. Regarding the first one here are the pictures. Lines are like vector elements. In the second one the for loop is executing but the assignment is incorrect, therefore the syntax error. Regards, Radovan Edited by user 27 May 2012 15:21:06(UTC)
Hi, thanks for the quick answer. It works now without any errors. So, this time the bug was the stupid user There is something irritating that even though the definition is wrong, the result will still be calculated correctly.
Originally Posted by: jabadu Hi, thanks for the quick answer. It works now without any errors. So, this time the bug was the stupid user There is something irritating that even though the definition is wrong, the result will still be calculated correctly. Hi, I tried to understand what happened in the example. My current guess is: The operations k:0result:line(for(i;range(1;length(X));line(k:k+1;el(result;k):el(X;i)*el(Y;i);2;1));result;2;1) use result to store the line structure of expressions symbolically. Whenever evaluation is requested by the = operator, then the stored expression is evaluated using the current value of all variables involved in the definition. Assignment to "result" just changes the definition. If the : Operator is meant to assign the evaluated result of some expression, then eval() has to be used. Any later change of variables used in the expression do not affect the content the formerly evaluated result. In both cases nothing seems to be wrong with using the same variable name as return value for the line operator and as target for the expression assignment. Replacing result by result1 inside the expression has no effect on the behavior (at least in this small example). This might be due to that the line operator shields parameter arguments in function definitions and return values from global name space result:eval(line(k:1;for(i;range(1;length(X));line(k:k+1;el(result;k):el(X;i)*el(Y;i);2;1));result;3;1))If you try to assign the for operator to a variable, this fails. result2:for(i;range(1;length(X));el(result1;i):el(X;i)+el(Y;i))result2 is undefined, result1 contains the expected vector. Based on that guess I would propose the following: - More specific error message (e.g. "Assignment of for statement is ignored" ) in the result2 case.
- Disabling of assignment to elements of line structures unless it is meant to edit or automatically generate them. In that case assignment of assignment expressions like el(result;1):k:2 or similar statements should be possible ;-)
Martin |
2 users thanked mkraska for this useful post.
on 28/05/2012(UTC), on 28/05/2012(UTC)
