Hi, plese look this strange behavior... here is the file in the image: angle_debug.zipregards, w3b5urf3r Edited by moderator 29 May 2012 01:06:06(UTC)
It is again all about optimization. Use Numerical optimization for the B_vfk, alpha_vfs or plot_2.
Regards, Radovan |
Thank you! Will fix it too.
I plan to fix all the known bugs of 0.94 and release new version tomorrow in the evening.
Thank you very much Another problem (I hope not to get you mad)... Typing these characters an error message (System.NullReferenceException) will appear; then if you want to continue using the program will appear another message error (System.InvalidCastException) these characters disappear if typed two times, and cause a similar error as above if typed 3 times (System.ArgumentOutOfRangeException) P.S. the bracket ] introduce the line() command and then appear the error message regards, w3b5urf3r Edited by user 19 May 2012 21:34:41(UTC)
You are right,
Just pressing ^ will cause the Unhandled exception (Win XP) Here are the Details
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at SMath.Control.MathRegion.(Int32 , Term ) at SMath.Control.MathRegion.(String ) at SMath.Control.MathRegion.OnCommandSend(String value) at SMath.Control.Worksheet.(String ) at SMath.Control.Worksheet.Insert(String value) at SMath.Control.Worksheet.(String ) at SMath.Control.Worksheet.Insert(String value) at SMath.Control.Worksheet.OnKeyPress(KeyPressEventArgs e) at System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m) at System.Windows.Forms.Control.ProcessKeyMessage(Message& m) at System.Windows.Forms.Control.WmKeyChar(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SMathStudio_Desktop Assembly Version: 0.94.4521.40097 Win32 Version: 1.1.21.0 CodeBase: file:///D:/Downloads/Software/SMath/SMathStudio_Desktop.exe
System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ioman Assembly Version: 0.94.4521.40086 Win32 Version: 0.94.4521.40086 CodeBase: file:///D:/Downloads/Software/SMath/ioman.DLL
Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
canvas Assembly Version: 0.94.4521.40092 Win32 Version: 0.94.4521.40092 CodeBase: file:///D:/Downloads/Software/SMath/canvas.DLL
System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
HTMLFileType Assembly Version: 1.9.4521.39825 Win32 Version: 1.9.4521.39825 CodeBase: file:///D:/Downloads/Software/SMath/plugins/HTMLFileType.dll
ImageFileType Assembly Version: 1.5.4521.39839 Win32 Version: 1.5.4521.39839 CodeBase: file:///D:/Downloads/Software/SMath/plugins/ImageFileType.dll
PictureRegion Assembly Version: 1.7.4521.39854 Win32 Version: 1.7.4521.39854 CodeBase: file:///D:/Downloads/Software/SMath/plugins/PictureRegion.dll
PlotRegion Assembly Version: 1.6.4521.39867 Win32 Version: 1.6.4521.39867 CodeBase: file:///D:/Downloads/Software/SMath/plugins/PlotRegion.dll
SMathFileType Assembly Version: 1.6.4521.39882 Win32 Version: 1.6.4521.39882 CodeBase: file:///D:/Downloads/Software/SMath/plugins/SMathFileType.dll
SpecialFunctions Assembly Version: 1.8.4521.39899 Win32 Version: 1.8.4521.39899 CodeBase: file:///D:/Downloads/Software/SMath/plugins/SpecialFunctions.dll
TextRegion Assembly Version: 1.7.4521.39913 Win32 Version: 1.7.4521.39913 CodeBase: file:///D:/Downloads/Software/SMath/plugins/TextRegion.dll
XMCDFileType Assembly Version: 1.8.4521.39928 Win32 Version: 1.8.4521.39928 CodeBase: file:///D:/Downloads/Software/SMath/plugins/XMCDFileType.dll
System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
NuLib Assembly Version: 1.61.4521.40090 Win32 Version: 1.61.4521.40090 CodeBase: file:///D:/Downloads/Software/SMath/NuLib.DLL
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Regards, Radovan |
To be fixed today as well.
Regards.
on 20/05/2012(UTC), on 20/05/2012(UTC)
Hi, great job, many bug fixed unfortunately, the bug System.ArgumentOutOfRangeException persists... involved characters: these characters "disappear" if typed two times (text area of text and the hints window becomes white, and drawing a selection with the mouse, the selected portion of the sheet becomes white too), and cause the message error if typed 3 times; if you want to continue then you can't close the sheet from the X button or the exit option (the only way is CTRL+ALT+DEL) regards, w3b5urf3r Edited by user 21 May 2012 14:00:28(UTC)
| Reason: extend bug description |
Hello w3b5urf3r,
I can't reproduce this and I thought this bug was "squashed" by Andrey. Could you please explain what keys should we press in order to get this problematic behavior you've explained.
Regards, Radovan
Hi, Just write in a blank area § -> no problem §§ -> white areas §§§ -> error message here I shared a video to show what happens: Smath bug video (codec:XviD) (red points on pointer when clicking with left mouse button) Edited by user 21 May 2012 14:56:17(UTC)
Thank you w3b5urf3r, I reproduce it now. I used my keyboard and there was no £ key. Inserting £ as ALT-0163 will cause the problems that you've presented in the video file - forced closing of SMath was needed then. This is happening only in math regions. Regards, Radovan Edited by user 21 May 2012 16:17:53(UTC)
Regards, Radovan Thank you for reproducing this bug... It is not critical, but sometimes an "heavy finger" on the keyboard can come to light it regards, w3b5urf3r |
Finally fixed: Thank you!
on 27/05/2012(UTC), on 28/05/2012(UTC)
