SMath Studio Forum
Questions
How to add rows to matrix by condition
If the value in the second column of the matrix is greater than the specified constant, then you need to replace the row containing this value by the number of rows equal to quotient of division of this number by constant + 1. In the first rows, the value in the second column must be equal to a constant, and in the last row the value in the second column must be equal to a remainder of the integer division of the number by a constant. On the left is the original matrix, on the right is what should be obtained.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,649 Location: Italy Was thanked: 1332 time(s) in 876 post(s)
That's a rough implementation, although I probably misunderstood some part. |
It should be something like this but probably there is a better decision
Seems I missed the physical meaning, this should be a better implementation: split layers.sm (11kb) downloaded 15 time(s).Edited by user 25 February 2021 15:14:47(UTC)
Originally Posted by: babalus There's not much to change, just add the units to: - threshold
- const
- rem, here you have to reintroduce the unit (automated by UnitsOf() or directly)
Edited by user 25 February 2021 19:01:24(UTC)
on 25/02/2021(UTC), on 26/02/2021(UTC)
Joined: 25/03/2021(UTC) Posts: 2 Location: Los Angeles
Hint: You can get a submatrix like this: subMatrix = fullMatrix(1:someRow, : ); subMatrix = fullMatrix(row1:row2, : ); subMatrix = fullMatrix(someRow:end, : ); % End has a special meaning (pick one), and you can concatenate matrices vertically like this: tallMatrix = [shortMatrix1; shortMatrix2]; % Use as many as you want They all have to have the same number of columns of course. I hope this helps, thanks! Edited by user 25 March 2021 13:45:05(UTC)
| Reason: Emoticons
SMath Studio Forum
Questions
