Offline hanskl
#1 Posted : 17 February 2021 12:27:00(UTC)
hanskl
Norway
Was thanked: 7 time(s) in 5 post(s)
Has anyone performed the Hardy Cross / Moment Distribution Method on a continuous beam in SMath? Are there any examples of this on the forum?
Best regards,
#2 Posted : 19 February 2021 22:25:07(UTC)
Hans, no much audience for that one !
My only competence is monkey see monkey do.
... not finished yet that demo.
Page1 Hardy-Cross.sm (51kb) downloaded 34 time(s).
Offline hanskl
#3 Posted : 20 February 2021 03:41:04(UTC)
hanskl
Norway
Jean,
Thanks for having a look.
Its the part below that is the technically new/challenging part for me. I cant quite visualize the "framework" to set it up if you will.
Best regards,
Offline loha
#4 Posted : 20 February 2021 08:09:55(UTC)
loha
Was thanked: 9 time(s) in 9 post(s)
Hi, I do that not by computation but graphically on CAD by moving the "baseline" which is substracted from an assumed simply-supported moment at each span. For me the advantage is, it's very visual so errors are instantly visible, options are also visually obvious, so design decisions can be taken quickly. (I draw parabola in CAD as segments of very very elongated ellipses).
#5 Posted : 20 February 2021 15:43:48(UTC)
steps are the missing links ... out of the blue !
