Offline davidlimtw
#1 Posted : 27 January 2021 22:23:36(UTC)
davidlimtw
Rank: Member
United Kingdom
I've have a loop interpolating and searching for values. I not sure what went wrong, the loop is suppose to return 4 answer, however I am only getting (1), the last value.
Appreaciate some help and guidane.
Page7.sm (46kb) downloaded 14 time(s).
#2 Posted : 28 January 2021 02:27:26(UTC)
Sorry Collab, I don't understand what you are interpolating.
That sub-spaces technique is very useful in many applications.
Page7 Subspaces.sm (42kb) downloaded 7 time(s).
on 28/01/2021(UTC)
Offline overlord
#3 Posted : 28 January 2021 03:48:48(UTC)
Turkey
Was thanked: 510 time(s) in 340 post(s)
Below you can find corrected file.
I have revised some equations in var_file() and G().
They were trying to reach out of matrix.
Since I don't have original mathcad file this is best I can do.
I did some error check but maybe you have to dig further.
Edited by user 28 January 2021 06:54:31(UTC)  | Reason: Not specified
on 28/01/2021(UTC)
Offline davidlimtw
#4 Posted : 28 January 2021 13:54:46(UTC)
davidlimtw
Rank: Member
United Kingdom
Hi Overlord,
Thanks for the reply. Although the val_file() is not returning the same answer as per the attached MathCAD but the overall loop actual works.
See attached calculation in mathcad.
Page 7.xmcd (98kb) downloaded 6 time(s).
Edited by user 28 January 2021 14:07:25(UTC)  | Reason: Not specified
Offline Razonar
#5 Posted : 28 January 2021 15:23:25(UTC)
Razonar
Uruguay
Was thanked: 826 time(s) in 523 post(s)
Hi Overlord,
Hi. val_find() returns the vector index, so it must to be the mathcad answer plus one, because ORIGIN:=0 in mathcad.
val_find.sm (135kb) downloaded 6 time(s).
on 28/01/2021(UTC)
#6 Posted : 28 January 2021 15:45:12(UTC)
Page19 Search_Locate.sm (370kb) downloaded 8 time(s).
on 28/01/2021(UTC)
Offline davidlimtw
#7 Posted : 28 January 2021 16:48:40(UTC)
davidlimtw
Rank: Member
United Kingdom
Thanks Alvaro for your comment.
Jean, that is cool stuff... you can draw something like this in the SMath...
Offline overlord
#8 Posted : 28 January 2021 16:54:19(UTC)
Turkey
Hi Overlord,
Having the mathcad file revealed the difference of two programs.
The problem is n_min and n_max in smath version.
Mathcad assigns them [0 0], [0 1] and [1 1] only, whatever you enter.
min_offset and max_offset can be calculated within bounds of 9x9 matrix by them.
By that, offsets are always lower then 9 during max_offset=ii*n_max+1.
Your current smath function will produce out of matrix.
Because n_min and n_max are [1 1], [1 2] and [2 2].
And by adding ii to them it will be bigger than 9.
Algorithm should be revised with respect to that.
n_min and n_max should be lowered by 1 to correct it.
You can find re-revised file according to this.
If anything is unusual you can tell, we will try to fix it.
Page7_re-revised.sm (48kb) downloaded 10 time(s).
on 28/01/2021(UTC)
Offline davidlimtw
#9 Posted : 28 January 2021 19:09:44(UTC)
davidlimtw
Rank: Member
United Kingdom
Hi Overloard,
Thanks for the comprehensive explaination. I will look into it and let you know if there are any bug.
#10 Posted : 28 January 2021 20:30:02(UTC)
Your project can be done entirely in Smath.
Unfortunately, it is not modular, unexplained
it reduces the de-bug sanity procedure.
