2 Pages<12
Offline ElSid
#21 Posted : 26 January 2021 03:56:11(UTC)
ElSid
Thank you. This came straight from the function that Ber7 and Jean helped with. It worked on my other sheet too, so this is more generic.
As the the units ... I need to adjust in plotting, not the function, thank you.
Edited by user 26 January 2021 04:33:52(UTC)  | Reason: Not specified
#22 Posted : 26 January 2021 04:45:48(UTC)
You just mentioned few minutes ago that your "Sound Pressure"
work sheet didn't work anymore. I still have it working fine.
The format incorrect, empty work sheet from your attachment.
Offline Ber7
#23 Posted : 29 January 2021 22:25:48(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Originally Posted by: ElSid Go to Quoted Post
Revisiting this old calc with SMath newer features and some function definitions.
  1. No longer works if I redefine the logarithmic sum with vectorize
  2. I cannot get the "heat capacity function" to work for ploting
Sound Loss (Quick).sm (477kb) downloaded 15 time(s).
Thanks for the help.
I suggest the "heat capacity function".
In calculation and on graph used not feet but meters.
List2.sm (24kb) downloaded 11 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 30/01/2021(UTC)
Offline ElSid
#24 Posted : 30 January 2021 02:56:29(UTC)
ElSid
Ber7,
Thank you! I gave up trying to figure out how to use the Mat2sys version. You are genius! Much like the manning equation, sound is "cleaner" to calculate in metric (no coefficient for unit conversions, etc.) Being in the US, I would require the plot and final solution to show in ft. I played with UofM(m)/ft to get the conversion factor for any distance you may want
Sound Ber7.sm (26kb) downloaded 15 time(s).
Guest (2)
Similar Topics
Calculating the speed of sound in wet steam (Questions)
by GerardLardner 25/03/2024 15:12:31(UTC)
Sound dB (Samples)
by ElSid 13/04/2018 20:40:30(UTC)
Sound dB again (Samples)
by Jean Giraud 12/04/2018 07:26:44(UTC)
2 Pages<12
