SMath Studio Forum
Bugs & Problems
Simple calculation is producing the wrong answer
I have come across an error when doing the folowing calculation.
-5.00+.85+.85+3.30=-4.44*10^-16 ( decimal places are set to 2)
The above equation should equal zero.
I am using the portable version .93 (build 4466 ) on Windows 7 Pro 64bit.
Thanks in advance.
I was wondering if anyone else can reproduce this symptom.
Thanks,
Hello lcesero. Yes, I've reproduced it. The only thing I can do here is to add an ability to replace answer with 0 if the result accuracy is less then or equal 10^-16. This way used by Mathcad as an option of every equation. Will think about it. Best regards, Andrey Ivashov. Edited by user 01 May 2012 21:30:00(UTC)
| Reason: Not specified
SMath Studio Forum
Bugs & Problems
