2 Pages12>
Offline ElSid
#1 Posted : 15 January 2021 20:14:08(UTC)
ElSid
Graphing is NOT my forte ...
Can we plot, quickly, a function that uses two ranges? I cannot find anything in my notes that will help me Heat Capacity.sm (15kb) downloaded 14 time(s).
#2 Posted : 15 January 2021 22:38:05(UTC)
Originally Posted by: ElSid Go to Quoted Post
Can we plot, quickly, a function that uses two ranges ?
The 2nd plot is only the XY axes system, as r and t are just multiple.
Maybe, there is a missing link ?
Heat Capacity.sm (23kb) downloaded 21 time(s).
Offline Ber7
#3 Posted : 15 January 2021 23:11:14(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
I suggest one of the options
Heat Capacity M.sm (19kb) downloaded 21 time(s).
Edited by user 15 January 2021 23:15:45(UTC)  | Reason: Not specified
Offline ElSid
#4 Posted : 15 January 2021 23:43:39(UTC)
ElSid
Jean,
Your file is giving me some of the dreaded "black boxes". Easy fix on the sheet. Just pointing it out as you are using "0.98.6179" and latest stable is "0.99.7610"
Thanks for your help
Ber7,
Thank you as well
#5 Posted : 16 January 2021 01:59:51(UTC)
Jean,
From recollection black boxes started appearing at 7610.
Reported many times by many ... not doctored then suffer.
The converse is true, i.e: 6179 open 7610 and more recent black.
Is it defendable ? ... update , you are retarded.
The truth is: it is a bug and I sign !
SS 6179 does not open black all 7610 and later.
Thanks Ber7, you got it right IMHO.
Offline ElSid
#6 Posted : 18 January 2021 23:40:33(UTC)
ElSid
Trying to take Ber7's help a little further.
Is there a way to "functionalize" the loop? I'm having an issue with UNITS (required). Not possible, because of units, is an acceptable answer. Heat Capacity Function.sm (29kb) downloaded 7 time(s).
#7 Posted : 19 January 2021 03:38:10(UTC)
Work sheet empty ... incorrect format.
Just re-post Ber7 document !
Offline Ber7
#8 Posted : 19 January 2021 08:24:08(UTC)
Ber7
Israel
Graph of a function with dimensionless arguments
Plot.sm (8kb) downloaded 12 time(s).
Offline ElSid
#9 Posted : 19 January 2021 19:51:11(UTC)
ElSid
Thank you again.
Looks like I was not clear with my question.
  1. Where you able to open my file? Jean had issues.
  2. I am trying to "generalize/discretize the loop" for other equations/functions where I have two range variables
  3. At one point, I had a third variable and that was the function/equation f(#x,#y):= ????; plot2rangevars:=(#x,#y,f(#x,#y)):={program}
Units are important as they fix the scalars ...
Re-uploaded file without a closed area to see if this helps Jean
Heat Capacity Function.sm (29kb) downloaded 6 time(s).
Edited by user 19 January 2021 20:25:29(UTC)  | Reason: Not specified
#10 Posted : 19 January 2021 21:05:57(UTC)
Just opened Ber7 document and completed to export the multiple data sets.
You can tabulate as well p2, p3, ... p6 then make a unique export table.
The meshed pivot is an exceptional tool, save it.
Plot Otherwise SS6179.sm (36kb) downloaded 12 time(s).
#11 Posted : 19 January 2021 23:01:14(UTC)
... super discretizer, algo style.
Offline ElSid
#12 Posted : 20 January 2021 03:08:42(UTC)
ElSid
You need to delete the units in the your version as BER7 had accounted for it in the function ... I know you hate units. I need to digest your follwup posted sheet
#13 Posted : 20 January 2021 17:49:12(UTC)
You can have it otherwise as well.
Page8 Elsid.sm (60kb) downloaded 10 time(s).
Offline ElSid
#14 Posted : 20 January 2021 22:01:51(UTC)
ElSid
Thank you Jean,
Really helpful. Is there a reason that a legend cannot be created on the plots (X-Y Plot) that are individual colors? I realize you used the built in graph and I updated my snippet sheet with the X-Y PlotCapture.PNG
NEVERMIND ... It'S under TRACES, not LEGEND
Edited by user 20 January 2021 22:08:41(UTC)  | Reason: ANSWERED myself
#15 Posted : 21 January 2021 00:08:02(UTC)
Thank you Jean,
X_Y plot does not recognize the multiple linterp, thus plots one trace only.
Alternately, you can add some sort of legend on the QuickPlot.
Page8 Elsid.sm (61kb) downloaded 8 time(s).
Offline ElSid
#16 Posted : 21 January 2021 02:36:22(UTC)
ElSid
Thank you Jean and Ber7.
This has turned into a rabbit hole to document (notes) how to plot an equation with two range variables with a function. Is there a way to eliminate #X1 (t1 in this example)? In short, is there a function? or way to eliminate the units from #X (t in this example). Heat Capacity Function1.sm (21kb) downloaded 26 time(s).
Didn't work how I wanted, but similar to dividing vectorized (t/Unitof(t)).
Edited by user 21 January 2021 04:23:06(UTC)  | Reason: Addded comment for UNITOF () Function
#17 Posted : 21 January 2021 04:47:42(UTC)
... again, document empty "Incorrect Format"
Ber7 did the 2 var collection in nested vector form,
my last version is table style, much more convivial as I'm used to do.
Units are just a pen in the ass[hole].
A good way is to work units-less, then append silent units.
Offline ElSid
#18 Posted : 21 January 2021 05:09:44(UTC)
ElSid
Not sure why you cannot open. The previous solution and worksheets work as intended. Thank you
I'm now trying to figure this out to fully make a "snippet" function as long as I define the the empirical equation divided by the units. It would have multiple applications for me.
Offline Ber7
#19 Posted : 21 January 2021 14:48:58(UTC)
Ber7
Israel
Graph with legend
Ps.sm (8kb) downloaded 8 time(s).
Offline ElSid
#20 Posted : 21 January 2021 17:17:04(UTC)
ElSid
Thank you guys. I should have just deleted the question when I figured out the legend issue in lieu of answering myself. As mentioned above, it was under TRACES, not LEGEND, in the X-Y Plot
Were you able to open up my last attachment? Jean had issues again Sad
This is my current hang up with the units
Edited by user 21 January 2021 17:28:17(UTC)  | Reason: Not specified
2 Pages12>
