Some direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix. ADR.sm (128kb) downloaded 9 time(s).Thank you
Originally Posted by: ElSid Some direction would be appreciated. Quick brute force for a range of values, AFAIU. Cheers old Collab Elsid ... Jean ADR brute force.sm (151kb) downloaded 11 time(s).
Originally Posted by: ElSid Some direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix Don't miss the Truth Table Companion in Samples. Cheers ... Jean
Aaah now I get what you meant. This should solve your problem. Deleted previous post. Regards Edited by user 11 January 2021 05:39:52(UTC)
| Reason: Not specified
Originally Posted by: overlord Aaah now I get what you meant. This should solve your problem. Deleted previous post.
Is this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you
Originally Posted by: ElSid Is this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you InterpBilinear() is in the 'Custom Functions' plugin. Basically an interpolation with two variable. Good and useful function. Regards
... from the attached example, get inspired to construct the data ready for matrix interpolation. Elsid Spline Table.sm (20kb) downloaded 15 time(s).
