I used the latest version 0.99 build 7561. The default font "Arial" cannot be changed as initial. If I need every TextRegion to be "Courier New", I have to individually changed the Font in all TextRegion or copy them. As I known, the font family of old version is fixed as "Courier New". It looks strange if I am editing the existing sheet and found mixing between "Arial" and "Courier New" I would propose to fix this problem or adding default font family in setting. Thank You Edited by user 27 September 2020 08:06:16(UTC)
| Reason: Not specified
Originally Posted by: knana232 It looks strange if I am editing the existing sheet and found mixing between "Arial" and "Courier New"
"Courier New" is the most comfortable Maths font. It makes uniform book style document in earlier Smath. Option to click in text region, change font style is missing as you say.
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1127 time(s) in 723 post(s)
Originally Posted by: knana232 I used the latest version 0.99 build 7561. The default font "Arial" cannot be changed as initial. If I need every TextRegion to be "Courier New", I have to individually changed the Font in all TextRegion or copy them. As I known, the font family of old version is fixed as "Courier New". It looks strange if I am editing the existing sheet and found mixing between "Arial" and "Courier New" I would propose to fix this problem or adding default font family in setting. Thank You It would help already if the font selection menu could be limited to just two fonts. It is quite annoying having to scroll through hundreds of fonts to find courier new. Alternatively, in old documents, just CTRL-drag (clone) any old region and overwrite the contents. Whenever I edit old documents, I mark all regions (CTRL-A) and switch them to Arial. Thus they are consistent with any new stuff. Any math region will ignore the font setting, thus no need to unselect them for document cleanup. |
