Offline Leandro Martins
#1 Posted : 22 September 2020 14:37:20(UTC)
Leandro Martins
Rank: Member
Brazil
Hello everyone.
I have an If shown in the image below. I would like that in addition to the result of the equation, it would also be shown from which equation the result originated.
It is possible?
#2 Posted : 22 September 2020 15:37:22(UTC)
It is possible?
Maybe ... but document is missing ... Ah !
Offline PompelmoTell
#3 Posted : 22 September 2020 16:14:47(UTC)
PompelmoTell
Leandro, for example like this:
Leandro.sm (8kb) downloaded 31 time(s).
As Jean says help us get help and always attach the smath file with the problematic example.
#4 Posted : 22 September 2020 17:37:05(UTC)
Leandro Martins
Rank: Member
Brazil
Thank´s so much Sergio. It´s Works very nice.
Next time I will put smath file.
Attach the math file only to check my solution. But this is in Portuguese!
Memoria de Calculo Monovia.sm (244kb) downloaded 29 time(s).
Edited by moderator 22 September 2020 20:31:08(UTC)  | Reason: Marked as solved
Offline Razonar
#5 Posted : 22 September 2020 23:41:26(UTC)
Razonar
Uruguay
Hi. Those are very similar to the Sergio (Pompelmo Tell) solution:
#6 Posted : 23 September 2020 15:31:24(UTC)
Often, if/otherwise is more convenient in program.
In some applications, program accepts only if/else.
Generally < is incompletely determined ... ≤ is completely determined.
It may result in an error message or simply an error w/o message.
if-else ... if-otherwise.sm (22kb) downloaded 24 time(s).
