Joined: 10/12/2009(UTC) Posts: 248 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Hi Andrey, I test the new version (0.93) and found the same problem that version 0.92. This is the result from same file. Plotting in 0.91: Plotting in 0.93: Regards, Oscar Edited by moderator 20 March 2012 10:33:36(UTC)
| Reason: Not specified
Hello Oscar, Here is the same file I reported it was wrong in v0.92 (the same post when you reported your problem). It seems to me quite right in v0.93. It must have been something else regarding your problem. Can not see what's wrong at the moment. Regards, radovan |
This was fixed in 0.93 (the reason was a bug regarding constants).
Regards.
smath wrote:This was fixed in 0.93 (the reason was a bug regarding constants).
Regards. Sorry, but in my post I show that problem persist in 0.93. It is not fixed. Regards, Oscar
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
oscampo wrote:smath wrote:This was fixed in 0.93 (the reason was a bug regarding constants).
Regards. Sorry, but in my post I show that problem persist in 0.93. It is not fixed. Regards, Oscar same results of oscampo with Smath 0.93, win7 http://www.mediafire.com/?6uf36mq2xc0ykvi |
oscampo wrote:Sorry, but in my post I show that problem persist in 0.93. It is not fixed. Ok. I'll check it. Thank you. Regards.
Hello, I think I found the problem. It seems it is again regarding Optimization Look at the first picture please: The blue line is a function of x, as in the Oscar's example. The red line is plotting two column vectors. I used the larger step just to see the difference. Either way the q1(x) has been calculated wrong. Here is another picture with Numerical optimization applied on both q1(x) and for loop. This time q1(x) has been calculated correctly. Unfortunatelly, the function plot is still wrong and I do not know how to change this. Actually there is a way by using eval() But another problem appeared. I can not see why the error in the third plot. Separate plot are possible but not the joined plot? Could someone try to reproduce or to explain this, please. Here is the file Oscarplot.sm Regards, Radovan Edited by user 07 March 2012 15:44:37(UTC)
Fixed. Regards.
on 20/03/2012(UTC), on 20/03/2012(UTC)
